Hmmm...
Took off at night on a heading going directly over the ocean. When I hit the gear up switch, I lost all power to the panel. I circled back, switched off all electrical except the master and got a flicker of power in the panel but not enough to work the radio's. I was hoping the generator ('62 Comanche) would charge up the battery, but when I looked at the amp-meter, the needle was at zero. Switched the transponder to 7700 (in case I got enought of a charge) and occasionally tried the radio (and clicked SOS with the PTT), but it when it became evident that the generator was gone, I lowered the gear manually, swung by the tower, thought I got a light and came back around to land. Held it off the runway for as long as I could, but guess the gear hadn't locked and down I went. 600' later (according to the airport police) I came to a stop, my passenger and I hopped out, and that, gentlemen, was that. This happened last Friday night, so there is still no information as to what went on with the electrical, but given the amp-meter reading 0 with no draw, it's a pretty good guess that the genny went out. As far as the gear not locking, with everything going on, it's possible that I hadn't slowed down enough before releasing the gear and therefore they couldn't lock, though it would have been nice if they had once I got down to approch speed :-) Thanks for ALL your suggestions - particularly the portable power supply - that would have saved the day. All the best - Fly safe... |
![]() "Lockrdg" wrote in message ... Hmmm... I lost all power to the panel. when it became evident that the generator was gone, I lowered the gear manually, swung by the tower, thought I got a light and came back around to land. Held it off the runway for as long as I could, but guess the gear hadn't locked and down I went. 600' later (according to the airport police) I came to a stop, my passenger and I hopped out, and that, gentlemen, was that. **************************** Sorry to hear about the gear up, but good to hear you made a great landing. You do get to use the equipment again, right? g\ Most importantly, no one got hurt. How bad is the plane? -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.714 / Virus Database: 470 - Release Date: 7/2/2004 |
Most importantly, no one got hurt. How bad is the plane? Yes - when it is fixed (I'm a partner) True - I had a passenger who is very happy to be on the ground. Not too bad. The expected bent prop and potential engine/gear work, and of course, the much thinner belly of the plane. What everyone remarked (fire and police) was how little debris there was off the plane. I would like to believe that it was my skill, though more likely luck, but I set the sucker down straight as an arrow and nestled it down directly on the middle of the fuselage. The bottom beacon was untouched. Will be quite a while before it flies again though. Guess I should just concentrate on building my multi time g. |
Destination Suggestions | Matt Young | Piloting | 9 | July 5th 04 03:17 AM |
Spousal checkride -- any suggestions? | Eric Ross | Piloting | 41 | June 21st 04 06:58 PM |
Bend, OR (S07) to OSH route suggestions | Jack Allison | Piloting | 4 | April 12th 04 09:19 PM |
Portable oxygen system suggestions... | hnelson | Owning | 3 | August 11th 03 08:39 AM |
Demo Flight Suggestions | Ben Jackson | Owning | 6 | July 12th 03 01:16 PM |
