![]() "Roger Long" wrote in message ... A friend of mine's IFR instructor showed him something I've never heard of. He rolled in 2 - 3 turns of nose up trim on our 172, pushed on a rudder pedal, and went into a nice level steep turn without touching the yoke. I'm not sure if this is practice for proper turn entry or a way of entering an emergency turn partial panel without the danger of over banking. Can anyone shed further light on this maneuver? -- Roger Long Roger; If he did this EXACTLY as you indicated, I make it a climbing left turn. Rolling in the trim even leading the rudder a little bit would cause a positive pitch immediately, then as the rudder was introduced, it would have to be very gentle to negate any adverse yaw. It would yaw into the left side ok if done this way, but it looks like the trim would have become the dominant factor by that time and a climbing left turn would be the result. These "maneuvers" were popular back in the early days of private pilot instrument introduction. There were several "save your life" maneuvers that were bantered around at that time; supposedly to save your butt if you got caught over the top, or inadvertently flew yourself into some bad weather. Frankly, I didn't like any of it then, and I still wouldn't advocate using it. This little ditty using the trim would be VERY difficult to get done in actual instrument conditions; this of course depending on the airplane being used. But my money would go on the trim and rudder use not being applied in the exact sequence required to produce a stable level turn. I'd bet the house on the trim being early and raising the nose on someone trying this in actual conditions, then the rudder yawing into a left climbing turn, which could REALLY get somebody who 1. didn't know enough not to be there to begin with....and 2. not know enough to make a simple normal instrument coordinated turn....into REAL trouble FAST!!!! The real answer to these little catch all ditties is for pilots to learn right from the gitgo, the right way to do things normally, and be able to control their airplane without all these "gadget turns"...then, have enough common sense to stay out of these bad weather situations where they need to use that control. :-)) Dudley |
Elite and CH Flight Sim Yoke - USB | tscottme | Instrument Flight Rules | 3 | December 21st 10 11:34 PM |
Why is a standard hold right turns? | Roy Smith | Instrument Flight Rules | 51 | August 28th 04 06:09 PM |
Beech dual yoke w/rams horns/color preference | Dan Karshin | Aviation Marketplace | 1 | March 28th 04 05:04 PM |
CH Product Yoke with IP Trainer 6.5 | Sanjay Kumar | Instrument Flight Rules | 2 | October 10th 03 07:47 AM |
Can F-15s making 9G turns with payload? | Paul J. Adam | Military Aviation | 114 | September 27th 03 05:47 AM |
