Yaesu/Vertex coax antenna adaptor
Old July 12th 04, 11:04 PM
Peter Gottlieb
What kind of adapter is it?
Is it a female sma to female BNC?
"RM" wrote in message
m...
Cub Driver wrote in message
I did a search on Google. If I recall correctly, the adapter cost $3
and the s/h $5, and I had it before I flew the next time.
$9.99 + s/h at pilotmall.com
$9.95 + s/h at Flight Essentials
Still think you recalled correctly? I'd be glad to be shown a better
store.
Old July 13th 04, 01:55 PM
RM
It's BNC male on one end, SMA female on the other. It fits onto the
Vertex antenna connector and allows a standard BNC cable to be connected
to the unit. $11 + s/h at pilotportal.com
"Peter Gottlieb" wrote in message t...
m...
store.
Old July 13th 04, 04:34 PM
Peter Gottlieb
Like this?
http://www.baproducts.com/rfa-8381.jpg
That one is $4.85 in single quantity, but I've seen them cheaper. Ask a ham
to pick you up one at the next hamfest for a couple of bucks.
Peter
om...
Old July 13th 04, 05:20 PM
RM
No, that is female on both ends.
Like this:
http://www.pacific-coast-avionics.co...il.asp?id=4072
Though if you think the asking price of a few beers is not as good
a deal as getting some theoretical ham buddy to get you one when he
gets around to it, that's fine by me.
Peter Gottlieb wrote:
Like this?
Peter
om...
Old July 13th 04, 06:08 PM
Jim Weir
Look at the picture closely. It is BNC female on the left and SMA male on the
right by my eyeball, even though I can't see inside the SMA end or the BNC end
with that tiny picture.
Tellya what. Take the adaptor you have. Look at the small SMA end. Is there a
pointed pin in the center or a pin with a hole in it? Look at the large BNC
end. Do the same eyeball. If it has a pointed pin, it is MALE; if it has a
hole in the pin, it is FEMALE.
RM
-No, that is female on both ends.
-Like this:
-http://www.pacific-coast-avionics.co...il.asp?id=4072
http://www.rst-engr.com
Old July 13th 04, 09:32 PM
Peter Gottlieb
Like this:
The "few beers" deal works for ONE person who happens to be close to you.
For everyone else it is more useful to have suppliers who have the item on
an ongoing basis.
Old July 13th 04, 04:42 PM
Jim Weir
Would you mind sexing (you should pardon the expression) that connector again?
The sex of an RF connector is determined by the CENTER PIN, and not the shell.
I think you mean BNC female to SMA male.
(RM)
-It's BNC male on one end, SMA female on the other. It fits onto the
-Vertex antenna connector and allows a standard BNC cable to be connected
-to the unit. $11 + s/h at pilotportal.com
Old July 13th 04, 04:49 PM
RM
You are correct. BNC female, SMA male.
(RM)
Antenna problems Mike Rapoport Owning 16 February 9th 05 06:04 PM
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 06:59 PM
Antenna ground plane and coax grounding G. Fred McCutchen Home Built 2 August 8th 04 12:27 PM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 03:27 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
