Would you mind sexing (you should pardon the expression) that connector again?
The sex of an RF connector is determined by the CENTER PIN, and not the shell. I think you mean BNC female to SMA male. Jim (RM) shared these priceless pearls of wisdom: -It's BNC male on one end, SMA female on the other. It fits onto the -Vertex antenna connector and allows a standard BNC cable to be connected -to the unit. $11 + s/h at pilotportal.com Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
You are correct. BNC female, SMA male.
Jim Weir wrote: Would you mind sexing (you should pardon the expression) that connector again? The sex of an RF connector is determined by the CENTER PIN, and not the shell. I think you mean BNC female to SMA male. Jim (RM) shared these priceless pearls of wisdom: -It's BNC male on one end, SMA female on the other. It fits onto the -Vertex antenna connector and allows a standard BNC cable to be connected -to the unit. $11 + s/h at pilotportal.com Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
"RM" wrote in message
... You are correct. BNC female, SMA male. Currently on auction http://cgi.ebay.com/ws/eBayISAPI.dll...84673 13&rd=1 ( http://makeashorterlink.com/?Z1B423BC8 ) http://cgi.ebay.com/ws/eBayISAPI.dll...9216 560&rd=1 ( http://makeashorterlink.com/?D3C424BC8 ) http://cgi.ebay.com/ws/eBayISAPI.dll...8514 618&rd=1 ( http://makeashorterlink.com/?T2D412BC8 ) Or e-bay stores: http://stores.ebay.com/RADIOSHOPSUPP...enameZl2QQtZkm ( http://makeashorterlink.com/?E31512BC8 ) http://stores.ebay.com/EE-INDUSTRIES...isplayZ2QQtZkm ( http://makeashorterlink.com/?N2F423BC8 ) And probably quite a few more. Paul |
Antenna problems | Mike Rapoport | Owning | 16 | February 9th 05 06:04 PM |
Retractable Comm Antenna | Ron Wanttaja | Home Built | 11 | September 6th 04 06:59 PM |
Antenna ground plane and coax grounding | G. Fred McCutchen | Home Built | 2 | August 8th 04 12:27 PM |
ELT antenna -- Pitts | Al MacDonald | Home Built | 0 | July 15th 04 03:27 PM |
Ext antenna connection for handheld radio | Ray Andraka | Owning | 7 | March 5th 04 01:10 PM |
