Diamond DA-40 with G-1000 pirep
Old July 19th 04, 05:06 PM
G.R. Patterson III
Dan Luke wrote:
"Thomas Borchert" wrote:
In Europe, the Diesel is a total winner.
It should be here, too.
There's no good argument for using them in the States. Gas isn't that much more
expensive (if at all) than Jet-A, and gas is readily available in the lower 48. When
that changes, you'll see more diesels here. Do a comparison of the diesel and gas
Maules. The diesel costs more, is slower (due to cooling drag), and carries less
weight (the engine weighs more). I also think it's pretty ugly, with that Hawker
Typhoon style cowling, but that's a personal opinion.
George Patterson
In Idaho, tossing a rattlesnake into a crowded room is felony assault.
In Tennessee, it's evangelism.
Old July 19th 04, 06:52 PM
C J Campbell
"G.R. Patterson III" wrote in message
more
lower 48. When
and gas
carries less
Hawker
The trouble is that the days of 100LL are numbered.
Old July 19th 04, 07:08 PM
G.R. Patterson III
But nearly all of our engines can run just fine on high-grade unleaded. That's what
will be in the pumps a few years from now. Diesels are popular in Europe because
gasoline costs four times what diesel costs. They will also be a good idea for pilots
who fly to places where gas is hard to get, like some parts of Canada and Alaska. As
long as there's something at the airport or the corner gas station that makes an
O-whatever work well, and that fuel isn't significantly more expensive than diesel,
diesels will not be common in U.S. GA aircraft.
George Patterson
Old July 20th 04, 02:22 AM
Tom Sixkiller
That's what
because
for pilots
Alaska. As
makes an
than diesel,
Lead in the Hogwash: http://www.avweb.com/news/columns/182149-1.html
Old July 20th 04, 08:16 AM
Thomas Borchert
G.R.,
Two to three times. But still...
Thomas Borchert (EDDH)
Old July 19th 04, 08:41 PM
Newps
I keep hearing that. And hearing that. And hearing that....
Old July 20th 04, 01:33 AM
C J Campbell
"Newps" wrote in message
Well, when it finally happens, you can't say that you weren't warned, can
you?
Old July 20th 04, 12:28 AM
Dude
There is a good argument, potentially, cost of operation.
The Centurion could, if well supported, and up to its marketing, replace
about every engine in the 140 to 180 HP range. That is a lot of engines.
Only problem is the chicken and the egg.
Who will pay to get all the mechanics trained? Will they put together good
english manuals, pdf's, videos? Will there be someone to call during normal
US hours who speaks english and knows the engine and the FAA regs?
100LL is not necessarily going away, but its possible that when it does, it
will go quickly. Also, the less we use, the more expensive it will get ( at
least that is my guess, perhaps someone else knows better.)
more
lower 48. When
and gas
carries less
Hawker
George Patterson
assault.
Thomas Borchert
Dude,
IMHO, the Centurion 1.7 simply is lacking the necessary power. 135 HP is
not enough. The sma design has its problems, namely weight, size and
price. But Thielert has seen the light: A V8, 300-HP version is in the
works for 2006, and a 6-cylinder around-200-HP version is at least
rumoured about.
Old July 21st 04, 05:45 AM
Dude
Ahh, but they, Thielert, have no plans to support the engine in the US (
nor does Superior). They think the plane manufacturers should do this.
Textron is delighted, as this will mean that they can continue to control
the business that has the best chance of defeating them. Diamond has
decided to offer Lycoming engines as an alternate for the Twin Star (which
must really please Textron)
btw- It's enough horsepower for the skyhawk and cherokee planes.
"Thomas Borchert" wrote in message
Dude,
rumoured about.
Cessna 182T w. G-1000 pirep C J Campbell Instrument Flight Rules 63 July 22nd 04 07:06 PM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Diamond DA-40 with G-1000 pirep C J Campbell Owning 114 July 22nd 04 05:40 PM
PIREP WANTED: Airmap 1000 [email protected] Piloting 2 June 5th 04 03:51 AM
GPSMAP 195/196 vs. Lowrance AIPMAP 1000 JJS Piloting 4 March 9th 04 08:14 PM
