Diamond DA-40 with G-1000 pirep
Old July 20th 04, 11:46 PM
Russell Kent
George Patterson wrote:
Do a comparison of the diesel and gas Maules. The diesel costs more,
True.
is slower (due to cooling drag),
It may be slower, but it doesn't "ring true" to me that the cause is higher
cooling drag. Diesel engines are more efficient than gasoline engines
because they extract more of the chemical energy as useful work, and less
chemical energy is converted to waste heat. With less waste heat, their
cooling drag should be *less* than a gasoline engine's.
and carries less weight (the engine weighs more).
True.
Russell Kent
Old July 21st 04, 12:52 AM
G.R. Patterson III
Well, they don't. They have a higher compression ratio, and that produces heat. The
SMA diesel is air-cooled, it produces more waste heat than an IO-540, and there's
more cooling drag than with an IO-540.
George Patterson
In Idaho, tossing a rattlesnake into a crowded room is felony assault.
In Tennessee, it's evangelism.
Old July 21st 04, 01:45 AM
Tom Sixkiller
"G.R. Patterson III" wrote in message
higher
less
heat. The
there's
Aren't they also heavier, i.e., pound of engine weight per HP generated?
Old July 21st 04, 02:35 PM
G.R. Patterson III
Every one of which I've read is heavier than an equivalent gas engine, especially
with all the accessories installed. Since some of the new diesel designs are
2-stroke, and most gas engines are 4-stroke, though, some of the newer ones may
actually come in lighter than the equivalent gasoline engine (if they ever make it to
production).
George Patterson
Old July 21st 04, 02:45 PM
Dave Butler
production).
Help me out here.
Why "especially with all the accessories installed"?
Why is a 2-stroke cycle engine lighter than a 4-stroke?
Thanks.
Dave
Old July 21st 04, 03:04 PM
G.R. Patterson III
The injection system tends to be more complex and heavier than gasoline models or
carburettors. This is because the injectors spray fuel directly into the cylinder
rather than into a section of the intake manifold. Many diesels handle the higher
CHTs by using water cooling systems, and those add weight (Lycoming was working on
one of these a few years ago). On the other hand, the glow plug systems used for
starting tend to be lighter than the magnetos used in gas engines.
The main cause of the weight difference is still the fact that everything must be
beefed up to handle the higher compression, though.
There are twice as many power pulses per minute with a 2-stroke. They usually are not
as efficient as a 4-stroke, so you don't get twice as much power, but they will
easily produce 1.6 times the power of a 4-stroke the same size, and most do better
than that. So a 200hp 2-stroke engine is smaller than a 200hp 4-stroke engine. In
addition, 2-strokes don't have a valve train, which saves some weight.
George Patterson
Old July 21st 04, 04:19 PM
Pete
-heavier high-pressure fuel pumps, lines etc which are not needed on gas
engines.
-on two strokes you need a supercharger to get them started.
-less stuff: with twice the power strokes per piston, one needs fewer
pistons and all associated stuff. For example the three cylinder Wilksch is
as smooth as a six cyl gas engine http://www.wilksch.com/
If only they could be lighter :-)
Cheers & blue skies,
Pete
Europa Builder A239 dual-wing
http://europa.zutrasoft.com
"Dave Butler" wrote in message
especially
are
ones may
ever make it to
production).
Help me out here.
Thanks.
Dave
Old July 21st 04, 04:17 PM
Thomas Borchert
G.R.,
None of those certified or close to certification are 2-stroke. And all
the Thielert engines are very close to the Avgas engines they replace,
weightwise.
Thomas Borchert (EDDH)
Cessna 182T w. G-1000 pirep C J Campbell Instrument Flight Rules 63 July 22nd 04 07:06 PM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Diamond DA-40 with G-1000 pirep C J Campbell Owning 114 July 22nd 04 05:40 PM
PIREP WANTED: Airmap 1000 [email protected] Piloting 2 June 5th 04 03:51 AM
GPSMAP 195/196 vs. Lowrance AIPMAP 1000 JJS Piloting 4 March 9th 04 08:14 PM
