G.R. Patterson III wrote:
Aren't they also heavier, i.e., pound of engine weight per HP generated? Every one of which I've read is heavier than an equivalent gas engine, especially with all the accessories installed. Since some of the new diesel designs are 2-stroke, and most gas engines are 4-stroke, though, some of the newer ones may actually come in lighter than the equivalent gasoline engine (if they ever make it to production). Help me out here. Why "especially with all the accessories installed"? Why is a 2-stroke cycle engine lighter than a 4-stroke? Thanks. Dave |
![]() Dave Butler wrote: Why "especially with all the accessories installed"? The injection system tends to be more complex and heavier than gasoline models or carburettors. This is because the injectors spray fuel directly into the cylinder rather than into a section of the intake manifold. Many diesels handle the higher CHTs by using water cooling systems, and those add weight (Lycoming was working on one of these a few years ago). On the other hand, the glow plug systems used for starting tend to be lighter than the magnetos used in gas engines. The main cause of the weight difference is still the fact that everything must be beefed up to handle the higher compression, though. Why is a 2-stroke cycle engine lighter than a 4-stroke? There are twice as many power pulses per minute with a 2-stroke. They usually are not as efficient as a 4-stroke, so you don't get twice as much power, but they will easily produce 1.6 times the power of a 4-stroke the same size, and most do better than that. So a 200hp 2-stroke engine is smaller than a 200hp 4-stroke engine. In addition, 2-strokes don't have a valve train, which saves some weight. George Patterson In Idaho, tossing a rattlesnake into a crowded room is felony assault. In Tennessee, it's evangelism. |
-heavier high-pressure fuel pumps, lines etc which are not needed on gas engines. -on two strokes you need a supercharger to get them started. Why is a 2-stroke cycle engine lighter than a 4-stroke? -less stuff: with twice the power strokes per piston, one needs fewer pistons and all associated stuff. For example the three cylinder Wilksch is as smooth as a six cyl gas engine http://www.wilksch.com/ If only they could be lighter :-) Cheers & blue skies, Pete Europa Builder A239 dual-wing http://europa.zutrasoft.com "Dave Butler" wrote in message ... G.R. Patterson III wrote: Aren't they also heavier, i.e., pound of engine weight per HP generated? Every one of which I've read is heavier than an equivalent gas engine, especially with all the accessories installed. Since some of the new diesel designs are 2-stroke, and most gas engines are 4-stroke, though, some of the newer ones may actually come in lighter than the equivalent gasoline engine (if they ever make it to production). Help me out here. Why "especially with all the accessories installed"? Why is a 2-stroke cycle engine lighter than a 4-stroke? Thanks. Dave |
Cessna 182T w. G-1000 pirep | C J Campbell | Instrument Flight Rules | 63 | July 22nd 04 07:06 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Owning | 114 | July 22nd 04 05:40 PM |
PIREP WANTED: Airmap 1000 | [email protected] | Piloting | 2 | June 5th 04 03:51 AM |
GPSMAP 195/196 vs. Lowrance AIPMAP 1000 | JJS | Piloting | 4 | March 9th 04 08:14 PM |
