Advancement of prop blade in flight, new information
Old August 16th 04, 10:35 PM
DanH
AJW wrote:
[snip]
For what it's worth, at 150 kts and 2500 RPM means the airplane advances about
6 feet per prop rev. A two bladed prop means each balde is in air 3 feet ahead
of the prior blade.
That's the same number I came up with, but that assumes there's a
one-to-one ratio between engine RPM and prop RPM. Is that true of all
single engine piston aircraft? I'm obviously not an AC mechanic, but I
thought I could see a reduction gear in the cowl.
DanH
Old August 16th 04, 11:13 PM
AJW
AJW wrote:
[snip]
about
ahead
of the prior blade.
I don't know of a SEL airplane in general use that uses reduction gearing
between the shaft and the prop, Dan.
Old August 17th 04, 04:59 AM
Mike Rapoport
Any airplane with a "G" in its engine designation.
Mike
MU-2
"AJW" wrote in message
AJW wrote:
[snip]
advances
about
feet
ahead
of the prior blade.
Old August 17th 04, 09:20 AM
Thomas Borchert
Ajw,
All Thielert Centurion driven aircraft - way over 100 and counting.
Thomas Borchert (EDDH)
Old August 17th 04, 10:14 AM
Dylan Smith
Many hundreds of examples of Europa aircraft. My friend's Europa runs
the 4-cylinder, opposed, liquid cooled 914S engine at something like
5400RPM in cruise. I think the prop turns less than half that RPM.
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
Old August 17th 04, 11:59 AM
Paul Sengupta
"Dylan Smith" wrote in message
In article , AJW
gearing
Or any Rotax engined plane.
Paul
Old August 17th 04, 04:00 PM
Thomas Borchert
Corky,
You don't see that so much anymore in certified airplanes
But you will, again.
Old August 28th 04, 01:40 PM
Big John
Corky
Computer dropped my add on to your posting so will try again.
Besides the round engines, the V's also had gearing. The Merlin in the
P-51 had a two to one (ie, engine ran 3000 rpm on take off and prop
turned 1500 rpm).
Big John
On Tue, 17 Aug 2004 08:03:06 -0400, Corky Scott
new theory of flight released Sept 2004 Mark Oliver Aerobatics 1 October 5th 04 10:20 PM
A question only a newbie would ask Peter Duniho Piloting 68 August 18th 04 11:54 PM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 02:54 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
