T-hangar's bi-fold door: Convert to a motorized opening door?
Old August 19th 04, 04:06 AM
G.R. Patterson III
"Peter R." wrote:
Perhaps some type of conversion to an automatic garage door opener?
Garage door openers drive a sprocket that operates a circular chain. Some of the
older units had a block on the chain that tripped a switch when the door was raised.
This block could be adjusted to fine-tune the system. My Genie units do not have
this. I assume (but do not know) that they simply pull the chain for a fixed distance
(most doors are 7' tall).
So. Measure the distance you have to pull your chain to open the hangar door. Work
out the ratio between that and 7'. Rig a reduction gear out of two appropriately
sized pulleys and a belt and drive that from a chain driven by a garage door opener.
You can probably use your existing chain pulley as one pulley in the reduction gear
and mount the whole thing high on the wall.
George Patterson
If you want to know God's opinion of money, just look at the people
he gives it to.
Old August 19th 04, 06:12 PM
Peter R.
Thanks, George. I might just try this project.
Peter
Old August 20th 04, 01:32 AM
Doordoc
Peter R. wrote in message ...
Actually many residential garage doors will open up a 10' high door
when they have the right length rail & chain. So if your door is 10'
tall you do not need to change the reduction at all, but if your door
is taller then 10' you would have to change the reduction. However if
you change the reduction very much (depends on door height) you are
also going to increase the speed that the door opens which may result
in an unsafe operating condition & is also going to put more wear &
tear on the door. Residential garage door openers are not designed for
this type of use & for your own safety is not something I would
personally recommend doing.
Doordoc
Old August 20th 04, 03:21 AM
G.R. Patterson III
Since this is a folding door, it's not a matter of the door height at all. It's
purely a matter of how much of the chain on his door he needs to pull to raise it
versus how much chain the opener pulls before it hits its limit switch. If the limit
switch on the GDO is adjustable, there's no need for a reduction mechanism at all.
George Patterson
he gives it to.
Old August 20th 04, 03:42 AM
Morgans
"Doordoc" wrote in message
om...
Some of the
door was raised.
do not have
fixed distance
hangar door. Work
appropriately
garage door opener.
reduction gear
Doordoc
I would say, that a proper application of a residential opener could be
safe, and reliable. It would take some doing.
Gear the output of the opener, so that the door moves at a speed comparable
to how fast the door would move, if it were being opened manually. This
would mean a much longer cycle time than the electric opener was designed
for, so the original limit switches would not work. A Craftsman (Sears)
opener, of older design had built in limit switches run by a threaded rod,
to control the start and stop locations, and thus times. Keep the concept,
but instead of pushing the switches using the built in threaded rod,
relocate new switches, so the doors physically push on the new switches to
start, stop, and reverse the movement.
I have my show sawdust system run by an old opener. The only parts I had to
buy were two new limit switches, and a bit of wire. The two new switches
are actuated by the threaded rod, but the original switches still start and
stop the opener. The new switches hold in the coil for the magnetic starter
circuit, and still let the pushbutton stations operate normally when the
remote is not being used.
Good luck. Contact me, if you want to make a go at it. I do happen to have
one more old opener on hand, :-))
Jim in NC
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.737 / Virus Database: 491 - Release Date: 8/11/2004
Old August 21st 04, 12:06 AM
John Clonts
"Morgans" wrote in message ...
[snip]
Hello Jim,
What in the world is a "show sawdust system"????
Thanks,
John Clonts
Temple, Texas
Old August 21st 04, 01:06 AM
Morgans
"John Clonts" wrote in message
Hello Jim,
Thanks,
John Clonts
Temple, Texas
Chuckle
That is the same as a "shop" sawdust system, but with fat thumbs, and late
at night.
In the event that you are not up with what I do, I teach carpentry in grades
10, 11 and 12. We have a pretty big cyclone, shared by two shops. It is
loud to talk over, so I wanted to turn it off and on at will, from anywhere
in the shop, thus the Rube Goldberg engineering. My students thought I WAS
CRAZY, until they saw it work. g
Jim in NC
Old August 19th 04, 11:33 PM
Peter Duniho
"G.R. Patterson III" wrote in message
Some of the older units had a block on the chain that tripped a
switch when the door was raised. This block could be adjusted to
fine-tune the system. My Genie units do not have this. I assume
distance (most doors are 7' tall).
They have essentially the same system, except that the block has been
replaced by an analog inside the opener. A worm drive moves a block back
and forth, that triggers switches at either end of the range of movement.
One end tells the opener when it's done opening, the other tells it when
it's done closing.
As with the older units, the end result is that the opener simply pulls the
chain for a fixed distance. In the case of the older units, the distance is
set by the block, in the newer units this is adjustable (within a small
range) by a setting that affects the exact position of the ends of the
internal mechanism.
hangar door. Work out the ratio between that and 7'. Rig a reduction
gear out of two appropriately sized pulleys and a belt and drive
Some problems I see with that:
* You will want to ensure that the mechanism inside the opener is up to
the task. The garage door opener I've had open has a nylon worm drive to
turn the main sprocket for the chain. It wears out even under normal garage
use, with a counter-spring to help reduce the forces involved. Even if the
hangar door is counter-weighted somehow, there may be more friction with the
larger door. It may be a lot to ask of little plastic pieces.
* The opener has a motor speed sensor that tells it when the thing is
getting bogged down too much. Because its main purpose is to avoid someone
getting crushed by the door, it's very sensitive. The sensitivity can be
adjusted somewhat, but probably not enough to account for a significant
difference in force required.
* To make matters worse, in combination with the above issues, a
reduction gear that increases the effective travel of the opener is
necessarily going to increase the force that the opener is required to
provide.
* Finally, using a belt and pulley system for the reduction gear may
result in the belt slipping. If it slips only at the very beginning of the
door movement, and it slips exactly the same amount when opening as when
closing, this might be okay. But otherwise, it will throw the system out of
adjustment.
I would say that with a large enough (i.e. expensive enough) garage door
opener, the above issues may not be a problem. But then you may start
finding that you'd have been better off just designing a custom-made opener
mechanism from scratch. Electric motors aren't that expensive, and the rest
is just a sprocket, switches and wiring, and possibly a new chain (depending
on what kind of "chain" is currently used with the manual opening system).
Pete
Old August 20th 04, 03:36 AM
G.R. Patterson III
I had assumed from the description that the opening mechanism on the hangar door is
similar to others with which I've dealt. In those, the chain is operated by hand and
requires only negligible force. It drives a gear that operates the actual opening
mechanism. Usually the gearing is such that the chain must be pulled a considerable
distance to raise the door, which is what results in it being so easy to pull around.
The doors with which I am familiar would require less from the GDO than normal garage
doors would require.
As for wearing out, there was a Craftsman unit in the house I used to own when I
bought it in 1988. It was still working well when I sold the house in 2001. The two
Genie units in my existing home were in it when we bought in 2000 and are doing just
fine so far. No telling how old they are. I installed one for a friend back in 1985
and it's still in service. The ones with which I've dealt are pretty bulletproof. You
might want to change brands the next time yours goes.
George Patterson
he gives it to.
Old August 20th 04, 05:59 AM
Peter Duniho
[...] The ones with which I've dealt are pretty bulletproof. You
The one I had to fix is a Craftsman. I don't know how old it is.
As far as the gearing/load issue goes: a certain amount of work (force over
distance) will be required to raise the door. If the hangar door needs to
be raised more distance than a garage door does, then more work will be
required for the hangar door, all else being equal.
Of course, if the hangar door is carefully counter-balanced and is on
frictionless mounts, then practically no force is required to move it, and
practically no work is required over the entire opening process.
But assuming that past the gear that reduces the force required on the chain
is a door that is similar in nature to a garage door with respect to the end
resultant force required to move it, you don't get something for nothing.
In order to "extend" the range of the garage door opener enough to match the
total range of the hangar door, you'll have to reduce the leverage of the
garage door so much that the force becomes an issue.
Pete
