Landing light circuit breaker 20 amp. Pops after about one minute.
	I have changed the landing light 4552, changed the CB and thought I had the problem solved. This morning Taxi at 6 am (still dark) I was pleased to have the landing light while in close quarters, then the CB popped. I have checked the wiring and connections and everything looks good. Will go with my trusty amp meter and see what the bulb draws. In the meantime can any one give some advise. The plane is a C 172 with the Avcon conversion. Thanks Hank  |
			 "Hankal" wrote in message ... Landing light circuit breaker 20 amp. Pops after about one minute. . Thanks Hank Check voltage drop across the switch. Could be high resistance in the switch. Could be corroded slide terminals that go on the bulb. Could be multi strand wires, with some of the strands broken. Find the culprit, as one of them could let you down, when most needed. Also, has anyone stole some power from that circuit, to power some avionics, or such? -- Jim in NC  |
 the CB popped.
	I have checked the wiring and connections and everything looks good. Will go with my trusty amp meter and see what the bulb draws. In the meantime can any one give some advise. The plane is a C 172 with the Avcon conversion. Thanks Hank Any chance something in the landing light fixture is grounding out as it heats?  |
			 "Morgans" wrote in message ... "Hankal" wrote in message ... Landing light circuit breaker 20 amp. Pops after about one minute. . Thanks Hank Check voltage drop across the switch. Could be high resistance in the switch. Could be corroded slide terminals that go on the bulb. Could be multi strand wires, with some of the strands broken. Find the culprit, as one of them could let you down, when most needed. Also, has anyone stole some power from that circuit, to power some avionics, or such? -- Jim in NC High resistance in the switch will make the current less, with less chance to pop the breaker. Likewise for corroded bulb terminals. Likewise for strands broken in the wires (as long as the strands are not breaking through the insulation and contacting the airframe. Now the breaker itself could develop high resistance contacts....heating the breaker internally and causing it to trip at a lower current than the rated 20 Amps. I suspect the breaker if the insulation on the wiring is in good shape. Also check the lugs and wires as they attach to the back of the breaker. If these are loose or corroded, the heated lugs can also warm the breaker causing premature tripping. J. Severyn  |
"Dan Thomas"  wrote in message
	om... The 4522 bulb is a 250 watt bulb at 13 volts. He wrote 4552, not 4522. The 4552 is a 28v 250W part, putting the current at below 10A. A 20A breaker ought to be entirely sufficient. If his post has a typo, and he actually means a 4522 bulb, then of course your post offers very useful information. Pete  |
	breaker internally and causing it to trip at a lower current than the rated 20 Amps. I suspect the breaker if the insulation on the wiring is in good shape. Also check the lugs and wires as they attach to the back of the breaker. If these are loose or corroded, the heated lugs can also warm the breaker causing premature tripping. I thought it was the breaker, but the new one does alo trip.  |
	heats? No everything is tight and nothing shorted. Hank  |
| Thread Tools | |
| Display Modes | |
| Skycraft Landing Light Question | Jay Honeck | Owning | 15 | February 3rd 05 07:49 PM |
| C-172 landing light switch | JFLEISC | Piloting | 16 | May 6th 04 02:15 AM |
| C-172 landing light switch | JFLEISC | Owning | 10 | May 6th 04 12:05 AM |
| The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 01:07 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
