I have wondered why some aircraft, use a small moveable control
surface seperate from the normal controls. I believe I have seen this in the form of a small wing under the horizontal stab being used as elevator trim. I once installed a trim tab on the back of the elevator on an Ultralight Challenger and induced severe flutter, something I did not want to repeat and obviously it is more than just deflecting the control. Ray On Thu, 24 Jun 2004 10:16:24 +0200, "Jan Carlsson" wrote: A small tab at the trailing edge is moving the control surface so the control surface is doing the job (trimming) by a small change in the angle, if the trim tab is sitting on a fixed part of the plane a bigger tab and or angle is needed. Jan "Jay" skrev i meddelandet . com... I've noticed that a lot of aircraft put trim tabs on the trailing edges of the normal movable control surfaces. Wouldn't this just deflect the control surface to neutralize the forces and not affect much change except drag? It seems like you'd want to put the trim tab on the fixed part of the wing/stab/vert, that way its pushing the airplane instead of the flight controls in your hands. I've noticed some articulated mechanisims on some aircraft (anti-servo) but this seems to be a complicated way to make up for the fact that the tab was put in the wrong place to begin with. What am I missing? |
Ray Toews wrote in message ...
I have wondered why some aircraft, use a small moveable control surface seperate from the normal controls. I believe I have seen this in the form of a small wing under the horizontal stab being used as elevator trim. I once installed a trim tab on the back of the elevator on an Ultralight Challenger and induced severe flutter, something I did not want to repeat and obviously it is more than just deflecting the control. Sometimes, a control surface will have "spades" extending either above or below it. As I understand it, they serve to reduce the control loads on that surface with high deflections. Usually, you'd see this on a very high-maneuverability aircraft (like those used for competition aerobatics). Adding such surfaces takes some knowledge though; you can't just slap one on without careful study or you might rip the entire surface off. Also, sometimes you see mass balances (usually like little teardrop shapes) extending forward of the surface. The best example of this that I can think of is on the P-38's elevator (though whether it was actually needed is still up for debate). I don't quite understand what those do as much, though I think they help with flutter. |
Bob
They balance the weight of the control surface equal on each side of the hinge. A better wording might be static balance. Am sure there will be others that add to this question. Big John On Sun, 27 Jun 2004 21:15:46 -0400, "Bob Martin" wrote: Ray Toews wrote in message ... I have wondered why some aircraft, use a small moveable control surface seperate from the normal controls. I believe I have seen this in the form of a small wing under the horizontal stab being used as elevator trim. I once installed a trim tab on the back of the elevator on an Ultralight Challenger and induced severe flutter, something I did not want to repeat and obviously it is more than just deflecting the control. Sometimes, a control surface will have "spades" extending either above or below it. As I understand it, they serve to reduce the control loads on that surface with high deflections. Usually, you'd see this on a very high-maneuverability aircraft (like those used for competition aerobatics). Adding such surfaces takes some knowledge though; you can't just slap one on without careful study or you might rip the entire surface off. Also, sometimes you see mass balances (usually like little teardrop shapes) extending forward of the surface. The best example of this that I can think of is on the P-38's elevator (though whether it was actually needed is still up for debate). I don't quite understand what those do as much, though I think they help with flutter. |
Ramifications of Cherokee Trim Jackcrew Failure | Bob Chilcoat | Home Built | 23 | June 9th 04 02:48 AM |
trim tab help | Robert Loer | Home Built | 0 | March 29th 04 08:30 AM |
pitot/static location | Ray Toews | Home Built | 2 | December 30th 03 12:52 AM |
Canard static port location | Paul Lee | Home Built | 1 | July 12th 03 02:55 AM |
