![]() "James M. Knox" wrote in message 2... "C J Campbell" wrote in : AP is saying two Russian jets crashed less than six minutes apart. Both airplanes departed Moscow. One crashed 120 miles south of Moscow and the other is presumed crashed 600 miles south of Moscow. Fuel problem??? What fuel problem would cause a jet to go down *right now*? Airliners glide decently and a crew with even a little training would get off a mayday call and try and work the situation in the time it would take a flamed-out airliner to go down. A back of the envelope figure is that an airliner probably has a sink rate of 2500 fpm or less in glider mode... Remember the Gimli Glider? It glided for 10-15 minutes before landing, and a Soviet airliner probably wouldn't do much worse... KB |
Kyle Boatright wrote:
What fuel problem would cause a jet to go down *right now*? TWA800 Gimli Glider? It glided for 10-15 minutes before landing, and a Soviet airliner probably wouldn't do much worse.. There was a Gimli glider style landing performed by Tupolev Tu-204 (757 lookalike) performed at night in Siberia after running out of fuel on the way to an alternate. They were lucky to be flying a latest Tupolev, since the older Tu-154 (one of the involved in yesterday's crash) have no RATs and their hydraulic system is completely dependent on the engines running (there are three of them plus APU after all), once they flame out, the -154 becomes uncontrollable and enters agriculture. Tu-134 on the other hand is old enough not to posesses hydraulic controls at all, other than a yaw damper, so this shortcoming becomes an advantage in such case. -- HECTOP PP-ASEL-IA http://www.maxho.com maxho_at_maxho.com |
On Wed, 25 Aug 2004 at 20:51:11 in message
, Kyle Boatright wrote: What fuel problem would cause a jet to go down *right now*? Airliners glide decently and a crew with even a little training would get off a mayday call and try and work the situation in the time it would take a flamed-out airliner to go down. A back of the envelope figure is that an airliner probably has a sink rate of 2500 fpm or less in glider mode... Remember the Gimli Glider? It glided for 10-15 minutes before landing, and a Soviet airliner probably wouldn't do much worse... More recently wasn't there an Airbus (I forget which type) that lost fuel over the Atlantic and glided some 70 nm(?) to the Azores and had enough height left for a circuit before landing? Modern airliners are efficient partly because they have very good Lift/Drag ratios. I agree that the sink rate is around 2000 ft/min or so but it is Lift/drag that gives you the distance. I guess that airliners cruise around 250 knots IAS and that that is near the optimum Lift/Drag ratio point. -- David CL Francis |
![]() "David CL Francis" wrote in message ... On Wed, 25 Aug 2004 at 20:51:11 in message , Kyle Boatright wrote: What fuel problem would cause a jet to go down *right now*? Airliners glide decently and a crew with even a little training would get off a mayday call and try and work the situation in the time it would take a flamed-out airliner to go down. A back of the envelope figure is that an airliner probably has a sink rate of 2500 fpm or less in glider mode... Remember the Gimli Glider? It glided for 10-15 minutes before landing, and a Soviet airliner probably wouldn't do much worse... More recently wasn't there an Airbus (I forget which type) that lost fuel over the Atlantic and glided some 70 nm(?) to the Azores and had enough height left for a circuit before landing? Modern airliners are efficient partly because they have very good Lift/Drag ratios. I agree that the sink rate is around 2000 ft/min or so but it is Lift/drag that gives you the distance. I guess that airliners cruise around 250 knots IAS and that that is near the optimum Lift/Drag ratio point. -- David CL Francis David, Agree with your L/D vs glide range comment. My point went to the idea that an airliner's sink rate is low enough that even with a complete flame out (unless the airplane was already at very low altitude), there should be plenty of time to get off a Mayday call and possibly relate the basics of the problem to a controller. KB |
On Thu, 26 Aug 2004 at 22:02:30 in message
, Kyle Boatright wrote: Agree with your L/D vs glide range comment. My point went to the idea that an airliner's sink rate is low enough that even with a complete flame out (unless the airplane was already at very low altitude), there should be plenty of time to get off a Mayday call and possibly relate the basics of the problem to a controller. In Macarthur Job's book where he describes the events when the BA 747 lost all 4 engines near Java he says that with all engines stopped at 37,000 feet the aircraft should take 23 minutes to sea level. That certainly reinforces your point! It also suggests a 1600 ft/minute descent rate. If the speed was 250k then, if I am right, it also implies a glide L/D of around 15. Airliners are _not_ bricks! :-) -- David CL Francis |
Two more Navy jets crash, one from Virginia Beach | Otis Willie | Naval Aviation | 0 | March 30th 04 11:40 PM |
best US jet vs Russian jets? | ville terminale | Military Aviation | 86 | March 12th 04 05:27 PM |
India rejects new Russian jets semi OT | Kevin Brooks | Military Aviation | 19 | December 17th 03 09:02 AM |
RUSSIAN WAR PLANES IN ASIA | James | Military Aviation | 2 | October 1st 03 11:25 PM |
Report blames pilots in crash of two Navy jets | Otis Willie | Naval Aviation | 0 | September 26th 03 01:27 AM |
