V-n Diagrams
Old August 28th 04, 04:17 PM
Greg Esres
On Sat, 28 Aug 2004 12:44:06 GMT, john smith wrote:
The difference between calibrated and indicated are within only 1-2
knots.
Around the stall speed, the error is normally much higher. When you
take sqrt(3.8) * Vs1 to get the hypothetical Va, you will normally get
a very different number if you use IAS vs. CAS.
I thought it was true airspeed that mattered?
No. Aerodynamic forces depend on CAS, rather than TAS.
As others have pointed out, it is permissible for a manufacturer to
set Va at a higher speed than what you will calculate using this
method. Most do not do so, however, but it's unclear what is guiding
Piper. Some of their POH's show stall speed as linear with weight,
which is blatantly untrue. If you start with this premise, Va is
likely to be off too.
Old August 28th 04, 06:30 PM
john smith
knots.
I am using Vs (stall, clean) since the configuration is the same as at Va.
How does CAS account for density altitude?
Old August 29th 04, 04:10 AM
Greg Esres
at Va.
Vs1 is normally taken to be the clean stall speed. The meaning of Vs
seems a bit more ambiguous. But we're talking the same thing here.
With a given CAS, the density altitude is irrelevant. That's the
beauty of it. ;-)
For a given DA, you could use TAS and get the same results, as long as
you're consistent in using TAS for each figure. However, Vs1 is only
published as CAS. And there's no point in doing that anyway.
Old August 29th 04, 04:38 PM
john smith
at Va.
beauty of it. ;-)
Thanks, Greg.
The whole purpose of my exercise is to determine the minimum turn radius
and maximum rate of turn for a given weight. This is dependent upon air
density (hence, density altitude) and true airspeed.
What is really interesting to me is, I learned all this stuff 25 years
ago, but didn't have the experience to fully understand it as I do now.
Old August 30th 04, 05:58 AM
Greg Esres
radius and maximum rate of turn for a given weight. This is dependent
upon air density (hence, density altitude) and true airspeed.
Hmmm. Air density doesn't appear in the formulas that I have. Load
factor and true airspeed are the only variables. And load factor
should be independent of density altitude.
What are you doing with air density?
Old August 30th 04, 02:48 PM
Jay Smith
Trying to figure minimum safe altitudes for recovery from vertical dives
at different times of the year under different temperature/humidity
conditions.
Maximum Sustained Turn Rate? Emilio Military Aviation 5 May 11th 04 03:12 AM
Piper Cheyenne wiring diagrams. Steve Piloting 1 April 7th 04 03:50 AM
FS: Aviation History Books Neil Cournoyer Military Aviation 0 August 26th 03 08:32 PM
