On Saturday I had my first opportunity to fly solo in actual since my
IR checkride. One of my biggest concerns since getting the rating was how I would make my first entry into actual without the benefit of an instructor at my side. With about ten hours of actual during my training I had always felt comfortable in that environment. But I knew the true test would be doing it alone, or almost alone. Another pilot who had just gotten checked out at my FBO and who had passed his instrument checkride about a week earlier wanted to go up, so I figured it would be a great opportunity to get some simulated instrument time, knock off a little rust , and get an approach or two in for currency. Congratulations on making this a true workout and well planned experience. But... Because the other pilot was only checked-out in planes with normally aspirated engines, we had to use one of the older 172s. You do understand that FAA regulations would not have stopped you using any single-engine plane? (you don't specify the difference) If he couldn't be acting PIC, you would have been acting PIC even while right seat. I'm assuming it's club regulations that forbade him either to be SP or left seat in the other plane. -- David Brooks |
"David Brooks" wrote in message ...
On Saturday I had my first opportunity to fly solo in actual since my IR checkride. One of my biggest concerns since getting the rating was how I would make my first entry into actual without the benefit of an instructor at my side. With about ten hours of actual during my training I had always felt comfortable in that environment. But I knew the true test would be doing it alone, or almost alone. Another pilot who had just gotten checked out at my FBO and who had passed his instrument checkride about a week earlier wanted to go up, so I figured it would be a great opportunity to get some simulated instrument time, knock off a little rust , and get an approach or two in for currency. Congratulations on making this a true workout and well planned experience. But... Because the other pilot was only checked-out in planes with normally aspirated engines, we had to use one of the older 172s. You do understand that FAA regulations would not have stopped you using any single-engine plane? (you don't specify the difference) If he couldn't be acting PIC, you would have been acting PIC even while right seat. I'm assuming it's club regulations that forbade him either to be SP or left seat in the other plane. -- David Brooks David, Since we wanted to switch seats at the destination, he wouldn't have been able to fly left seat without being checked out. Dave |
"David B. Cole" wrote in message
m... Since we wanted to switch seats at the destination, he wouldn't have been able to fly left seat without being checked out. As David said, that would be a club regulation issue. The FAA has no prohibition against you acting as PIC from the right seat, nor against him manipulating the controls from the left. Perhaps you should clarify whose rules you're talking about and what you mean by "checked out". Pete |
Peter,
I understand that, which is why in the original post I stated that he was only checked out in normally asirated planes. When I hear the term "checked out" it usually means being authorized to use the planes of a particular operation. As far as I know the FAA doesn't see any difference between normally aspirated and fuel injected engines, so I thought it was obvious it was an operator restriction. Maybe there is another meaning and if so I will provide more clarity in the future. Dave "Peter Duniho" wrote in message ... "David B. Cole" wrote in message m... Since we wanted to switch seats at the destination, he wouldn't have been able to fly left seat without being checked out. As David said, that would be a club regulation issue. The FAA has no prohibition against you acting as PIC from the right seat, nor against him manipulating the controls from the left. Perhaps you should clarify whose rules you're talking about and what you mean by "checked out". Pete |
Yes; I just wanted to verify this is the case because there are common
misapprehensions about the regulatory qualifications needed to fly the plane or act as SP. I suppose your phrase "normally aspirated" as opposed to "fixed gear" or "under 200HP" should have clued me that wasn't what you meant. -- David Brooks "David B. Cole" wrote in message m... Peter, I understand that, which is why in the original post I stated that he was only checked out in normally asirated planes. When I hear the term "checked out" it usually means being authorized to use the planes of a particular operation. As far as I know the FAA doesn't see any difference between normally aspirated and fuel injected engines, so I thought it was obvious it was an operator restriction. Maybe there is another meaning and if so I will provide more clarity in the future. Dave "Peter Duniho" wrote in message ... "David B. Cole" wrote in message m... Since we wanted to switch seats at the destination, he wouldn't have been able to fly left seat without being checked out. As David said, that would be a club regulation issue. The FAA has no prohibition against you acting as PIC from the right seat, nor against him manipulating the controls from the left. Perhaps you should clarify whose rules you're talking about and what you mean by "checked out". Pete |
Dave, along the lines of "clarity" which you mentioned:
"Normally aspirated" contrasts with "Supercharged", while "Carbureted" contrasts with "Fuel Injected". But that's OK -- we all finally understood what you meant. If I were renting out fuel-injected or and/or supercharged airplanes, I'd also want to be sure my renters understood how to operate them. But I see no reason for the FAA to be involved in the matter. ---JRC--- "David B. Cole" wrote in message = m... Peter, =20 I understand that, which is why in the original post I stated that he was only checked out in normally asirated planes. When I hear the term "checked out" it usually means being authorized to use the planes of a particular operation. As far as I know the FAA doesn't see any difference between normally aspirated and fuel injected engines, so I thought it was obvious it was an operator restriction. Maybe there is another meaning and if so I will provide more clarity in the future. =20 Dave =20 |
"John R. Copeland" wrote: If I were renting out fuel-injected or and/or supercharged airplanes, I'd also want to be sure my renters understood how to operate them. But I see no reason for the FAA to be involved in the matter. Other than some quirks in how you start them, I can't think of anything you really need to know about fuel injection to safely fly a fuel injected airplane. Certainly nothing that couldn't be taught in a couple of minutes (i.e. "there's no carb heat"). Supercharging is a bit more complicated. You can get into trouble and/or damage the airplane, if you don't know how the system works. A much steeper learning curve is mastering the current crop of avionics. Somebody who did their instrument training with 2 NAV/COMs and an ADF can get themselves into a world of hurt if they launch into IMC with a modern GPS and think they can figure it out as they go. I guess the FAA figures people are smart enough to not do that. |
Roy Smith wrote: Other than some quirks in how you start them, ....which don't show up until your renter has flown to a distant airport, shut down, and now wants to restart the hot engine. ![]() injected airplane. Certainly nothing that couldn't be taught in a couple of minutes (i.e. "there's no carb heat"). You just made me realize that I should know more about my alternate air than I do... -- Ben Jackson http://www.ben.com/ |
First Solo In Actual Conditions | David B. Cole | Instrument Flight Rules | 22 | September 3rd 04 11:40 PM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
Catastrophic Decompression; Small Place Solo | Aviation | Piloting | 193 | January 13th 04 08:52 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
FAR 91.157 Operating in icing conditions | O. Sami Saydjari | Instrument Flight Rules | 98 | December 11th 03 06:58 AM |
