Four blade prop on a Bonanza?
Old September 4th 04, 03:33 AM
Peter R.
Default Four blade prop on a Bonanza?
Today I just saw a four blade prop on a V-tail Bonanza at Niagara Falls
Airport, NY. This seemed a bit unusual to me, but then again, I only
have a few years of flying experience. What are the advantages and
disadvantages of this type of prop?
Peter
Old September 4th 04, 05:04 AM
Peter Duniho
"Peter R." wrote in message
The only Bonanza I've seen a four-blade prop on was a turbine conversion.
In that case, I'm pretty sure it's a classic example of being the only
practical way to get all of the available power converted to thrust
efficiently without hitting the ground with the prop.
Whether that was the case for the Bonanza you saw, I can't say.
Old September 4th 04, 06:12 PM
On Fri, 3 Sep 2004 22:33:46 -0400, Peter R.
Here's what the people that sell 'em have to say about it:
http://www.colemill.com/conversion%2...e%20specs.html
TC
Old September 4th 04, 07:35 PM
Orval Fairbairn
A couple of guys here have them, but I haven't discussed the
merits/demerits of the installation. The blades are certainly skinny,
though!
Old September 5th 04, 12:05 AM
On Sat, 04 Sep 2004 18:35:17 GMT, Orval Fairbairn
snip
though!
Not familiar with the toothpick variety installed on the Bonanza's.
Have been around several Panther/Panther II conversions with the
"wider" 4-blade props. Have played around with a DB meter comparing
them to like aircraft with the 3-blade installation.
There is not a large difference in the "noise" level, but IMHO the
extra blade shifts the apparent frequency of the prop beat, and makes
it appear to be quieter in the cockpit/cabin. The noise/vibration is
slightly higher/smoother.
The pilots I worked with related that they really didn't think there
was much difference performance-wise (comparing 350 hp to 350 hp, not
310 or 325 to 350).
TC
Old September 5th 04, 06:23 AM
Roger Halstead
Every time I try that link it says "connection refused".
I don't know what they say but if it's other than the following I'd
have some serious doubts.
More blades mean shorter blades for a given HP rating.
Shorter blades means less noise.
Bos with 2 blade props are noisy! Tips are supersonic.
More blades also raises the frequency of the noise and that lowers the
apparent noise level.
More blades are less efficient. in cruise, but better climb.
More blades mean less vibration, but they have to be suited to the
harmonics of the engine and engine balance weights.
www.rogerhalstead.com
TC
Old September 5th 04, 04:09 PM
Tom S.
"Roger Halstead" wrote in message
Works for me...here's what they say:
(Understand, though, that the Q-Tip propellers are quite good at cruise as
well as TO and climb)
New Continental IO-550B 300 horsepower -- for more speed, better climb
and reliability.
New Hartzell 4-blade "Q-Tip" propellers with Woodward governor for an
extremely quiet, vibration-free ride.
Shadin Digiflow fuel computer -- for extremely precise fuel management.
All new accessories, hoses and belts -- for hours of trouble free
service.
Only 10 working days downtime
Compared to a stock Bonanza the Colemill STARFIRE modification gives you...
Shorter takeoff roll
Increase rate of climb
Faster cruising speeds
Much quieter cabin
Distinctive new look
Would that be a kick in the ass when hooked to a Turbo Normalizer.
Old September 5th 04, 04:52 PM
Tom S.
and reliability.
management.
service.
Much quieter cabin
Advancement of prop blade in flight, new information Corky Scott Piloting 35 August 28th 04 02:00 PM
Survey - 3 blade prop conversion- Cockpit vibration, happy or not Fly Owning 20 June 30th 04 05:32 PM
Hartzelll 3 blade prop Matt Whiting Owning 6 June 15th 04 01:29 AM
Pitch and Diameter of 3 blade prop for IO-360 200HP Bart D. Hull Home Built 1 December 11th 03 11:42 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
