"AJW" wrote in message
... What Mooney jocks learn pretty quickly is that landing the thing is a bit diferent than say a 182. It's clean, so going from 1.3Vso to stall takes more distance than in an aiplane that isn't as aerodynamically clean. It has a very low wing, so if you get into ground effect going just a little faster than you should, you'll have increased the needed landing distance a lot. Agreed. While I'm not an instructor, I have sat in the right seat while at least 4 different pilots got to know the Mooney. That makes 5 pilots I know of who learned about the need for precise speed control the looooong way. As for taking off in a crosswind, I'm not sure what technique is being used for rolling along on one wheel, but in my airplane I keep it on the ground -- all three wheels -- until I have the airspeed I want for liftoff in a crosswind, and then I lift it off. There's nothing to be gained by having the yoke back, even on a short field, until you can lift off. Well that's what I do too. The problem seems to be that at about 45 to 50 kt, the wing, low and clean, starts producing substantial lift, taking the weight off the wheels. At that sort of speed, the side force on the fuselage from a strong crosswind can get to the level at which the wheels can't maintain enough grip on the runway to resist. In flight (and for landing) it's easy -- you just stick the upwind wing down. But unless you're prepared to do that on take-off, you (I) can't stop the thing moving sideways, particularly if the runway is wet, or uneven. Aerodynamics dictates that this limit must exist, and it certainly kicks in earlier than full rudder travel on the M20J. But it may differ for different circumstances, and I'm sure that careful handling and lots of practice allows you to get closer to the absolute limit. Julian Scarfe |
Opinions on a M20J | Jon Kraus | Owning | 62 | September 17th 04 12:12 AM |
Opinions on Cessna 340, 414 and 421 | john szpara | Owning | 55 | April 2nd 04 09:08 PM |
Opinions wanted | ArtKramr | Military Aviation | 65 | January 21st 04 04:15 AM |
Rallye/Koliber AD's and opinions | R. Wubben | Owning | 2 | October 16th 03 05:39 AM |
Rallye/Koliber AD's and opinions | R. Wubben | Piloting | 2 | October 16th 03 05:39 AM |
