Source for Sensenich props, new or used/Sparrow Hawk
Old September 6th 04, 07:34 PM
Scott Skylane
Paul Folbrecht wrote:
I want (need) a new prop for my C152. Sensenich has a 12-week lead
time. Are there other sources?
2nd question: Anybody have any comments the Sparrow Hawk conversion?
Paul,
1. http://www.propellerman.com/
although, they may be a bit "pre-occupied" today...
2. We converted our fleet of 152's years ago, and have been pleased
with the results. Lower spark plugs stay cleaner, the revised baffling
is more serviceable, and of course the performance improvement is
welcome, if not dramatic. Only real drawback is that the piston rings
tend to get "soft" at about 1500 hours, probably due to increased heat
of cumbustion. A quick hone and new ring set cures that, and its off
for another 1500 hours.
Happy Flying!
Scott Skylane
N92054
Old September 8th 04, 01:50 AM
Paul Folbrecht
Another real drawback I learned of is the decrease of TBO from 2400 to
2000. But thanks.
Paul,
Happy Flying!
Scott Skylane
N92054
Old September 8th 04, 02:20 AM
Scott Skylane
2000. But thanks.
/snip/
Paul,
Unless the airplane will be flying under part 135 or 121, the TBO figure
is meaningless. We routinely flew our engines 3500-4000 hours between
overhauls. This, of course, was only acheivable due to the high
utilization rates (about 100 hours per month, year-round). Your mileage
probably WILL vary, but I really don't think the Sparrowhawk conversion
has any meaningul effect on the engines life, other than the prior
mentioned ring issue.
Remember, to get the 2400 hour "TBO" on a regular O-235 L2C, you must
use a specific heavy piston part number, as well as "100% Genuine
Lycoming Parts" throughout the rest of the engine. Install even one
aftermarket valve cover gasket, and *poof*, the "TBO" magically drops
back to 2000 hours. As I said, meaningless...
Happy Flying!
Scott Skylane
N92054
Source for Sensenich props, new or used/Sparrow Hawk Paul Folbrecht Owning 4 September 8th 04 02:20 AM
A Remote Compass- java source [email protected] General Aviation 0 July 3rd 04 06:39 PM
4130 sheet source Leon McAtee Home Built 7 May 2nd 04 08:29 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
Source for copper crush gaskets??? Jim Owning 0 August 22nd 03 06:31 PM
