I didn't write down what fix types I was using before starting
my experimentation and as a result I couldn't find any combination which would give me SACRI and still be below the 32k limit. (I found SACRI in the AOPA flight planner, and both my Garmin and Lowrance databases have it, but after checking I couldn't find it on the VFR or IFR charts.) Per your suggestion I dropped all of the fix types and went to VFR/IFR/High-IFR, got all of my fixes back, and had enough room to put private airports and NDBs back into the database (about 25,500 waypoints, almost 5000 less than I had before). I had dropped the private airports and NDBs when I started flying IFR and had to add all of those fixes. To answer your original question, I think the chart method of selecting fixes is much better than the type selection method. I now have private airports which gives CoPilot a leg up over my expensive GPSs which don't. On Wed, 8 Sep 2004 20:31:04 +0000 (UTC), (Paul Tomblin) wrote: In a previous article, ArtP said: I tried just using the IFR/VFR chart symbols. The good news is my database went from 30,000 records to 15,000. The bad news is that every one of my routes now has missing waypoints. It seems that many of the IFR intersections are missing (ie. SACRI which is the intersection of EMI/272 and ENO/318). Both the FAA data and the DAFIF say that SACRI is only on the high altitude en-route chart. Try selecting high altitude en-route. |
To answer your original question, I think the chart method of selecting fixes is much better than the type selection method. I now have private airports which gives CoPilot a leg up over my expensive GPSs which don't. Great to hear it. -- Paul Tomblin http://xcski.com/blogs/pt/ I use shell scripts at ork. Some cow-orkers refuse to touch them, their excuse is usually "I don't understand perl". Their fear of perl is such that all things unknown are also perl. -- Andrew Dalgleish |
Associate Publisher Wanted - Aviation & Business Journals | Mergatroide | Aviation Marketplace | 1 | January 13th 04 08:26 PM |
Associate Publisher Wanted - Aviation & Business Journals | Mergatroide | General Aviation | 1 | January 13th 04 08:26 PM |
MSNBC Reporting on GA Security Threat | Scott Schluer | Piloting | 44 | November 23rd 03 02:50 AM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
