tscottme wrote:
Thanks for the lesson. Rolling to drop the nose is something I will keep in mind, should I need it. Congrats for keeping your head and working the problem. Scott I've seen a mention here previously of doing this, and I'm wondering if someone here could comment on the aerodynamics of this. It's not obvious to me that for a given elevator position, rolling to keep the nose level would affect the likelihood of a stall. You are stopping the airplane from climbing, but the stall speed has increased because you are in a bank. Are you actually flying further from a stall if the elevator is in a "climb" position but you bank the plane to stay level? -- David Rind |
David Rind wrote: I've seen a mention here previously of doing this, and I'm wondering if someone here could comment on the aerodynamics of this. It's not obvious to me that for a given elevator position, rolling to keep the nose level would affect the likelihood of a stall. You are stopping the airplane from climbing, but the stall speed has increased because you are in a bank. Bank angle does not affect stall speed, the increased load factor that comes with a banked turn does. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
to keep the nose level would affect the likelihood of a stall. Agreed. The elevator position determines the AOA. Banking the airplane keeps more or less the same AOA, but the associated speed will increase. If the a/c didn't stall in the bank, then it likely wasn't going to stall in straight flight, particuarly with only 1/3 "up" and a forward CG. |
Greg Esres wrote: If the a/c didn't stall in the bank, then it likely wasn't going to stall in straight flight, particuarly with only 1/3 "up" and a forward CG. Gee Greg, sure wish you had been in the airplane with me. You could have explained to the airplane that it wasn't "likely" to do what it was doing. Ok, perhaps it wouldn't have exceeded the critical AOA causing a stall, but the pitch angle was going to be excessive. If left alone it would have pitched over seeking trim speed with a resultant zoom right back up. Not a ride I wanted to participate in...and I'm comfortable with pitch and bank angles that most people probably are not comfortable with. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
As I recall, you said it stabilized at about 80 kts, reduced power, slight
descent. Sounds like you had a nice approach set up. 80 might be a tad high for a light 206. At what speed did it stabilize with no power? Also sounds like the phugoid contributed to the adrenaline level. Dale wrote in message ... In article , Greg Esres wrote: If the a/c didn't stall in the bank, then it likely wasn't going to stall in straight flight, particuarly with only 1/3 "up" and a forward CG. Gee Greg, sure wish you had been in the airplane with me. You could have explained to the airplane that it wasn't "likely" to do what it was doing. Ok, perhaps it wouldn't have exceeded the critical AOA causing a stall, but the pitch angle was going to be excessive. If left alone it would have pitched over seeking trim speed with a resultant zoom right back up. Not a ride I wanted to participate in...and I'm comfortable with pitch and bank angles that most people probably are not comfortable with. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Question:
Say again your thoughts/concerns/decisions regarding flaps extension? Thx, VL PS: Good job on the landing! |
That's my interp. |
"dennis brown" wrote: As I recall, you said it stabilized at about 80 kts, reduced power, slight descent. Sounds like you had a nice approach set up. 80 might be a tad high for a light 206. At what speed did it stabilize with no power? Less than about 14 inches and the nose would drop, more than about 14 inches and the nose would pitch up. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
I think if you would look really closely, the airspeed would stabilize at a
pretty much given number with a fixed elevator position. Whether you climb, cruise or descend would depend on power. The rest is probably the phugoid motion causing the airspeed variations. One of these times do some experimenting with blocked controls. Or disconnected controls. You can simulate blocked by using various sized stuff to keep the stick fixed. To simulate disconnected, let go. I found I could easily control my aircraft by using flaps instead of elevator. In fact it seemed so stable that I let go of the ailerons and rudders also. So no elevator, no aileron, no rudder. Just flaps. It established a spiral and just stayed there. I could only get it to tighten up a bit by letting the phugoid get more severe. When I damped out the phugoid, the spiral lessened and it went back to a stable spiral descent. This would have been a bail out situation for me because it would mean contacting the ground with the tip first. Add a tad of rudder or aileron control and it would have been quite survivable. One other interesting thing, I could not get it to establish a straight ahead wings level stable condition (no fair touching the stick or rudders after you let go). It would eventually end up in a stable shallow spiral one direction or the other. Maybe I need to look at the flaps and see how they match up. On the other hand, I think I'll just keep my chute on and know that if the controls all break at the same time it's time to jump. How many others of us know how many controls can break before they need to jump? What? They don't know? Dale wrote in message ... In article , "dennis brown" wrote: As I recall, you said it stabilized at about 80 kts, reduced power, slight descent. Sounds like you had a nice approach set up. 80 might be a tad high for a light 206. At what speed did it stabilize with no power? Less than about 14 inches and the nose would drop, more than about 14 inches and the nose would pitch up. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Space Elevator | Big John | Home Built | 111 | July 21st 04 04:31 PM |
Space slingshot was: Space Elevator | Keith Goodwin | Home Built | 1 | June 29th 04 04:11 PM |
Wanted - Cessna U206A elevator | Colin Fitzmaurice | Owning | 0 | May 18th 04 11:06 AM |
Wanted - Cessna U206A elevator | Colin Fitzmaurice | Owning | 0 | May 18th 04 11:05 AM |
Wanted - Cessna U206A elevator | Colin Fitzmaurice | Owning | 0 | May 1st 04 03:51 PM |
