Jammed Elevator
Old September 13th 04, 03:26 AM
Greg Esres
If left alone it would have pitched over seeking trim speed with a
resultant zoom right back up. Not a ride I wanted to participate
in.
That part I can agree with.
I'm not criticizing your performance, because you did well in an
emergency, but I do think that it's important not to let any readers
walk away with the idea that the way to prevent a stall is bank the
aircraft.
Old September 13th 04, 05:54 AM
Dale
aircraft.
Stall was a poor choice of words. I used roll to control pitch. With
an undesired pitchup I think most of us would be thinking about a stall.
I was flying again today and played around a bit on a couple of flights.
The initial elevator position was closer to 1/2 up than 1/3. As the
jumpers are climbing out to exit the power is down to 10 inches or so,
airspeed is about 65kts and I trim nose up since they are moving forward
to exit. After they leave the drill is to close the door, power back up
to 18 inches and pushover for descent. With that much elevator
deflection bringing the power up causes a strong pitchup. I held the
elevator as immobile as I could and allowed it to pitchup to see what
would happen. At about 30-35 degrees of pitch it started to roll off to
the left, airspeed was below 40IAS.
Dale L. Falk
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
Space slingshot was: Space Elevator Keith Goodwin Home Built 1 June 29th 04 04:11 PM
Wanted - Cessna U206A elevator Colin Fitzmaurice Owning 0 May 18th 04 11:06 AM
Wanted - Cessna U206A elevator Colin Fitzmaurice Owning 0 May 18th 04 11:05 AM
Wanted - Cessna U206A elevator Colin Fitzmaurice Owning 0 May 1st 04 03:51 PM
