![]() "Maule Driver" wrote in message om... My impression was that it 'stopped flying' before it looked like it stopped flying. I think that's what dooms many a pilot because they continue to pull after the aircraft as already stalled but before any sort of break. Looked like the dreaded downwind turn to this old RCer And yes, there is no such thing as a downwind turn except as an optical illusion that effects the pilot. It looked to me like it had already made the downwind turn and was turning back into the wind when it crashed. Bob |
![]() "Bob" "Maule Driver" My impression was that it 'stopped flying' before it looked like it stopped flying. I think that's what dooms many a pilot because they continue to pull after the aircraft as already stalled but before any sort of break. Looked like the dreaded downwind turn to this old RCer And yes, there is no such thing as a downwind turn except as an optical illusion that effects the pilot. It looked to me like it had already made the downwind turn and was turning back into the wind when it crashed. Bob I went back and looked again. It did look like a stall out of turn to me. It appeared to be perfectly oriented for the 'downwind' turn type of event. I've seen many dozens of them (done a few myself). The clouds and the sock suggest that et was a blustery, variable wind day which just makes it even more challenging to fly. There appears to be a momentary bump where the nose drops and the bank increases well before the turn completes 90 degrees - that looks like a stall. Did this thing have true to scale spoilers for bank? Having said that, there's no way to know for sure without telemetry. Flight instruments is part of what makes full scale flight easier in so many ways. Damn what a fine looking ship! |
It looked to me like the pilot might have gotten confused which wing
was low and then corrected the wrong way. As the roll was continued, the nose fell through. When an RC plane is flying and the light is behind it, its often easy to get confused which wing has dipped to know which way to correct. In that circumstance, you only know you've got it wrong when it responds the opposite of what you thought it should. A normal turn would have been back towards the camera to come back over the runway, not away as he ended up doing and crashing. "Bob" wrote in message ... "Maule Driver" wrote in message om... My impression was that it 'stopped flying' before it looked like it stopped flying. I think that's what dooms many a pilot because they continue to pull after the aircraft as already stalled but before any sort of break. Looked like the dreaded downwind turn to this old RCer And yes, there is no such thing as a downwind turn except as an optical illusion that effects the pilot. It looked to me like it had already made the downwind turn and was turning back into the wind when it crashed. Bob |
I understand the illusion of the "downwind turn" to an RC pilot and the
difficulty to keeping it straight in your mind which way to apply aileron with the model coming at you. However, there was a famous video involving a real B-52 at Fairchild AFB, WA where the pilot was hot-rodding low passes and turns. The old bomber overbanked and spiraled in just like the model did in the video - except the real B52 only managed 1/2 turn before impact right in front of the camera. I'm wondering if this is a real behavior of the B52 that was accurately modeled in the RC crash. If so, it's a credit to the accuracy of the model builders. Sad to see their loss. Bill Daniels "Jay" wrote in message om... It looked to me like the pilot might have gotten confused which wing was low and then corrected the wrong way. As the roll was continued, the nose fell through. When an RC plane is flying and the light is behind it, its often easy to get confused which wing has dipped to know which way to correct. In that circumstance, you only know you've got it wrong when it responds the opposite of what you thought it should. A normal turn would have been back towards the camera to come back over the runway, not away as he ended up doing and crashing. "Bob" wrote in message ... "Maule Driver" wrote in message om... My impression was that it 'stopped flying' before it looked like it stopped flying. I think that's what dooms many a pilot because they continue to pull after the aircraft as already stalled but before any sort of break. Looked like the dreaded downwind turn to this old RCer And yes, there is no such thing as a downwind turn except as an optical illusion that effects the pilot. It looked to me like it had already made the downwind turn and was turning back into the wind when it crashed. Bob |
![]() Wasn't that a B2 instead of a B-52? Bill Daniels wrote: I understand the illusion of the "downwind turn" to an RC pilot and the difficulty to keeping it straight in your mind which way to apply aileron with the model coming at you. However, there was a famous video involving a real B-52 at Fairchild AFB, WA where the pilot was hot-rodding low passes and turns. The old bomber overbanked and spiraled in just like the model did in the video - except the real B52 only managed 1/2 turn before impact right in front of the camera. I'm wondering if this is a real behavior of the B52 that was accurately modeled in the RC crash. If so, it's a credit to the accuracy of the model builders. Sad to see their loss. Bill Daniels "Jay" wrote in message om... It looked to me like the pilot might have gotten confused which wing was low and then corrected the wrong way. As the roll was continued, the nose fell through. When an RC plane is flying and the light is behind it, its often easy to get confused which wing has dipped to know which way to correct. In that circumstance, you only know you've got it wrong when it responds the opposite of what you thought it should. A normal turn would have been back towards the camera to come back over the runway, not away as he ended up doing and crashing. "Bob" wrote in message ... "Maule Driver" wrote in message r.com... My impression was that it 'stopped flying' before it looked like it stopped flying. I think that's what dooms many a pilot because they continue to pull after the aircraft as already stalled but before any sort of break. Looked like the dreaded downwind turn to this old RCer And yes, there is no such thing as a downwind turn except as an optical illusion that effects the pilot. It looked to me like it had already made the downwind turn and was turning back into the wind when it crashed. Bob |
Sort of. The B-52 crash at Fairchild was a simple accelerated stall, no
spin. It stalled at a near-90 degree bank angle and slid sideways into the ground. Very tragic. There was a white paper written by a USAF major some time afterward that examined the leadership and airmanship climate prior to the crash that makes fascinating reading. I may even have an electronic copy of it if anyone's interested. Shawn "Jerry Springer" wrote in message k.net... Wasn't that a B2 instead of a B-52? Bill Daniels wrote: I understand the illusion of the "downwind turn" to an RC pilot and the difficulty to keeping it straight in your mind which way to apply aileron with the model coming at you. However, there was a famous video involving a real B-52 at Fairchild AFB, WA where the pilot was hot-rodding low passes and turns. The old bomber overbanked and spiraled in just like the model did in the video - except the real B52 only managed 1/2 turn before impact right in front of the camera. I'm wondering if this is a real behavior of the B52 that was accurately modeled in the RC crash. If so, it's a credit to the accuracy of the model builders. Sad to see their loss. Bill Daniels "Jay" wrote in message om... It looked to me like the pilot might have gotten confused which wing was low and then corrected the wrong way. As the roll was continued, the nose fell through. When an RC plane is flying and the light is behind it, its often easy to get confused which wing has dipped to know which way to correct. In that circumstance, you only know you've got it wrong when it responds the opposite of what you thought it should. A normal turn would have been back towards the camera to come back over the runway, not away as he ended up doing and crashing. "Bob" wrote in message ... "Maule Driver" wrote in message r.com... My impression was that it 'stopped flying' before it looked like it stopped flying. I think that's what dooms many a pilot because they continue to pull after the aircraft as already stalled but before any sort of break. Looked like the dreaded downwind turn to this old RCer And yes, there is no such thing as a downwind turn except as an optical illusion that effects the pilot. It looked to me like it had already made the downwind turn and was turning back into the wind when it crashed. Bob |
ShawnD2112 wrote:
Sort of. The B-52 crash at Fairchild was a simple accelerated stall, no spin. It stalled at a near-90 degree bank angle and slid sideways into the ground. Very tragic. There was a white paper written by a USAF major some time afterward that examined the leadership and airmanship climate prior to the crash that makes fascinating reading. I may even have an electronic copy of it if anyone's interested. Shawn I read it off the web site, very interesting but took me about 1/2 hour. Just goes to show what happens when people stick their heads in the sand especially the middle management that were afraid to pass on "bad" news to their superiors! John |
On Tue, 14 Sep 2004 17:38:11 GMT, "ShawnD2112"
wrote: Sort of. The B-52 crash at Fairchild was a simple accelerated stall, no spin. It stalled at a near-90 degree bank angle and slid sideways into the ground. Very tragic. There was a white paper written by a USAF major some time afterward that examined the leadership and airmanship climate prior to the crash that makes fascinating reading. I may even have an electronic copy of it if anyone's interested. Here's a URL to the case study: http://s92270093.onlinehome.us/crmdevel/resources/paper/darkblue/darkblue.htm A terrible tragedy. Marty |
om... It looked to me like the pilot might have gotten confused which wing was low and then corrected the wrong way. It's a little hard to imagine that a pilot susceptible to that particular challenge of RC flying would be flying the B52. I flew for many years and yet never completely got past my training that included pushing the stick towards the down wing when it's coming at you. My brother is an accomplished pattern flyer and I recently asked him whether he still used that. He laughed and tried to explaing that he 'is completely in the plane and always oriented". Anyway, it was a pretty simple turn, a large aircraft, and close in... I don't think so.... but without a black box, we're all guessing. In any case, I've watched so many RC aircraft bite the dust in this way. Usually on the turn from downwind to final. It was SOP to blame the radio, and back in the 60 and early 70s, that was more than plausible. But I remain convinced that the vast majority of those accidents were stall-spin. Back then, all modelers had free flight and other experience. Practically all RC planes were test glided before first flight (long after it was practical for the higher loaded ones). A stall was known to require a nose up deck angle and would typically have a clear break after a noticeable deceleration. On the otherhand, accelerated stalls and turning stalls occured all the time and yet they were infrequently identified as such. The B52 crash is what such a stall looks like. If you look closely, you can even see the break. If he had been higher, a spin or at least a steep spiral would have developed. But it is all just conjecture. I watched a full scale glider do a such stall on the turn to final. The reasons for getting too slow were unclear but the pilot immediately knew it was a stall going into a spin. He saved his life by correctly applying corrective down elevator and perhaps rudder. After recovering into a pretty steep dive he leveled the wings and pulled out just in time to pancake onto an interstate. Blew the gear and crunched the belly but didn't even ding a wing tip. We got him out of there before the State Police even showed up. As the roll was continued, the nose fell through. When an RC plane is flying and the light is behind it, its often easy to get confused which wing has dipped to know which way to correct. In that circumstance, you only know you've got it wrong when it responds the opposite of what you thought it should. A normal turn would have been back towards the camera to come back over the runway, not away as he ended up doing and crashing. "Bob" wrote in message ... "Maule Driver" wrote in message om... My impression was that it 'stopped flying' before it looked like it stopped flying. I think that's what dooms many a pilot because they continue to pull after the aircraft as already stalled but before any sort of break. Looked like the dreaded downwind turn to this old RCer And yes, there is no such thing as a downwind turn except as an optical illusion that effects the pilot. It looked to me like it had already made the downwind turn and was turning back into the wind when it crashed. Bob |
Slightly OT- Model B52 Crashes | Howard Eisenhauer | Home Built | 22 | September 14th 04 09:54 PM |
FS: Revell Monogram "F-14A Tomcat" Plastic Model Kit (1:48 Scale) | J.R. Sinclair | Aviation Marketplace | 0 | August 16th 04 05:59 AM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
FA: 5 Airplane Model Kits - Bomber, Jet, Warbird | Disgo | Aviation Marketplace | 0 | February 22nd 04 05:00 PM |
FA: Bomber Plane Model MIB - Monogram 1/48 HEINKEL | Disgo | Aviation Marketplace | 0 | February 21st 04 02:40 PM |
