Nomex doesn't protect you from the heat or keep you from getting a thermal
burn- it simply won't catch fire itself or melt on your skin. You can also get a used one for under $100, which is a lot cheaper than any handheld radio or GPS. Actually, if you're going to wear a suit, you should also consider gloves and socks as well as a "turkey bag" flame hood. |
"Viperdoc" wrote in message
... Nomex doesn't protect you from the heat or keep you from getting a thermal burn I don't think I suggested it did. I certainly never intended to. It's a point worth keeping in mind though. - it simply won't catch fire itself or melt on your skin. You can also get a used one for under $100, which is a lot cheaper than any handheld radio or GPS. That's not any cheaper than a used handheld radio or GPS. Pete |
Not quite correct.
Nomex will burn in a fire - but it won't support combustion (ie you couldn't put a match to a suit hanging from a coat hanger and expect it to go up in flames). As a rule it supports a higher temperature before burning as well, compared to normal everyday clothes. Additionally, when you remove the source of the flame it won't leave charred remains smouldering. It's thermal insulation (for just the suit) is minimal (as you rightly point out) - the increased thermal protection comes from the layered nomex under garments. I think a lot of people mis-understand the purpose of a nomex suit - it's not to allow you to sit in a burning cockpit as flames reduce everything around you to smouldering ash - it's to significantly reduce your injuries from burns in the 5 to 10 seconds you have to get the hell out of a burning wreckage and clear of the fire - or if you like, use that time to assist someone else who isn't as well protected. "Viperdoc" wrote in message ... Nomex doesn't protect you from the heat or keep you from getting a thermal burn- it simply won't catch fire itself or melt on your skin. You can also get a used one for under $100, which is a lot cheaper than any handheld radio or GPS. Actually, if you're going to wear a suit, you should also consider gloves and socks as well as a "turkey bag" flame hood. |
It sure makes a difference to own your own plane!! | Marco Rispoli | Piloting | 9 | June 29th 04 11:15 PM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | March 1st 04 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | February 1st 04 07:27 AM |
Conspiracy Theorists (amusing) | Grantland | Military Aviation | 1 | October 2nd 03 12:17 AM |
A Good Story | Badwater Bill | Home Built | 15 | September 3rd 03 03:00 PM |
