... And it looks like the small jets are pushing the turbo props and the twin piston engines. Is it a matter of time before it will be cheaper to just buy a small jet? I'm not holding my breath on that one. Me either. But if you believe the manufacturer's claims, it is just a matter of time. Several of the "mini jet" designs under development are cheaper than the existing turboprop models, single or twin, and cost about the same as new piston twins. Of course, you can't actually buy any of them right now, and it remains to be seen what they will actually cost if and when they make it to market. What puzzles me is why there doesn't appear to be anyone working on turbines in the range of 160 to 250 HP for aircraft. GA Flyer just included an "engines in development" article as part of their Oshkosh coverage, and had a picture of exactly that, as well as a mention in the article of the company producing the small turbines (I think they said all for turboprop installations). They are out there...you just need to look. Don't get distracted by the lack of certificated engines, or lack of interest in certification. Not all of the engine research and development going on is aimed at the certificated market. Pete |
![]() "Peter Duniho" wrote in message ... wrote in message ... And it looks like the small jets are pushing the turbo props and the twin piston engines. Is it a matter of time before it will be cheaper to just buy a small jet? I'm not holding my breath on that one. Me either. But if you believe the manufacturer's claims, it is just a matter of time. Several of the "mini jet" designs under development are cheaper than the existing turboprop models, single or twin, and cost about the same as new piston twins. Of course, you can't actually buy any of them right now, and it remains to be seen what they will actually cost if and when they make it to market. What puzzles me is why there doesn't appear to be anyone working on turbines in the range of 160 to 250 HP for aircraft. Small turbines are inherently inefficient so you are unlikely to see them in this power range. The fuel consumption might be double that of a diesel. Mike MU-2 GA Flyer just included an "engines in development" article as part of their Oshkosh coverage, and had a picture of exactly that, as well as a mention in the article of the company producing the small turbines (I think they said all for turboprop installations). They are out there...you just need to look. Don't get distracted by the lack of certificated engines, or lack of interest in certification. Not all of the engine research and development going on is aimed at the certificated market. Pete |
"Mike Rapoport" wrote in message
news ![]() Small turbines are inherently inefficient so you are unlikely to see them in this power range. You're not listening. I already HAVE seen them in that power range. The likelihood of having done so is irrelevant, since it's already happened. The fuel consumption might be double that of a diesel. It might be be, I don't know. Nevertheless, they do exist... Pete |
I meant that you are unlikely to see them on production aircraft. Sorry I
wasn't clearer. Mike MU-2 "Peter Duniho" wrote in message ... "Mike Rapoport" wrote in message news ![]() Small turbines are inherently inefficient so you are unlikely to see them in this power range. You're not listening. I already HAVE seen them in that power range. The likelihood of having done so is irrelevant, since it's already happened. The fuel consumption might be double that of a diesel. It might be be, I don't know. Nevertheless, they do exist... Pete |
nk.net... I meant that you are unlikely to see them on production aircraft. I'll buy that. Though, I wouldn't go so far as to say it could never happen. Who knows? Maybe there's an application where reduced weight or increased reliability is more important, or perhaps the "fundamental" inefficiencies of small turbines will turn out to not be so fundamental after all. But you are right, for now the existing low-power turbines show no sign of being targeted for certified, production aircraft. Pete |
![]() "Peter Duniho" wrote in message ... "Mike Rapoport" wrote in message nk.net... I meant that you are unlikely to see them on production aircraft. I'll buy that. Though, I wouldn't go so far as to say it could never happen. Who knows? Maybe there's an application where reduced weight or increased reliability is more important, or perhaps the "fundamental" inefficiencies of small turbines will turn out to not be so fundamental after all. But you are right, for now the existing low-power turbines show no sign of being targeted for certified, production aircraft. Pete My understanding is that the reason that small turbines are less efficient than large ones is because of efficiency losses at the tips of both the compressor and turbine and the internal drag of the engine surfaces. Both of these issues get more pronounced as things get smaller. Similiar to a pipe with a cross sectional area of 1"sq flowing less than half as much fluid as one with a cross section of 2" sq. That is not to say that the engines will not get more efficient, it just means that small turbines will be less efficient than large ones. Mike MU-2 |
this power range. The fuel consumption might be double that of a diesel. It's not true, first off. Although bigger engines have advantages of Reynolds numbers and such, small and large are relative terms. The relationship of BSFC of heavy diesels and industrial gas turbines in steady state peak operation is pretty constant across engines from the size of an 855 cid Cummins to the really big guys with four foot bores. The turbocharged diesels are somewhat more efficient but nowhere near 2:1. The "secret" of linearizing gas turbine performance across a wide range of output power is thermal feedback, or regeneration. Look carefully at the real progenitor of the Cruise Missile turbojet... |
I don't disagree with you Dean on the spares issue etc., but as I see
it is you add up the cost of the engine and spares and then the fuel used over 40K hours or so and see where the real $ are. I also don't disagree about two different vintage engines; newer are more efficient, but look at the SFC on a CF6 of about 40K thrust and a CF34 of 9K thrust (same vintage) and I bet the larger engine has the upper hand; maybe not. Good discussion subject and it would be interesting to hear from others who know what they are talking about. Obviously anything I say comes from being around these things, not because I profess to be any kind of authority. Any aircraft turbine engineers out there? Neat thing about aviation is there is always something to be learned. |
