On Thu, 24 Jul 2003 02:33:33 GMT, clare @ snyder.on .ca wrote:
Apparently it IS possible to make a silk purse out of a sow's ear - and the 3.8 as supplied by Ford IS a sow's ear. The current crop, from 198? on is leak prone and fragile. The commonly supplied antifreeze, when it gets into today's oil, makes short work of the factory supplied bearings. There are gaskets and build procedures that can make a relatively leak-proof 3.8. Is there a combination of oil, antifreeze, and bearing that will not result in instant death when they are combined???? For this reason I have reservations about the 3.8. I'm well aware of the problems Ford has had with leaking cylinderhead gaskets with this engine. That's why I bought the ARP cylinderhead studs instead of replacement cylinderhead bolts from Ford. Studs allow a more accurate torque setting because the only thing turning is the nut against the washer, not the entire bolt. ARP recommends that you use either their lubricant between the nut and washer or oil. If you use their lubricant, the torque value is a LOT less than if you use oil. In addition, you get to use all the threads available to hold the stud in: you thread it down till it bottoms. The nice thing about having a cast steel block is you don't have to worry about stripping the threads out of the block. ARP also recommends that you install "throw away" head gaskets for the first torque of the cylinderhead, then fire up the engine, bring it to temperature and then shut it down and let it cool to room temperature. Once it's completely cooled, remove the heads, replace the head gaskets with new, reinstall the heads, retorque and you're good to go for the rest of the life of the engine. What this does, they said, is get the studs initially stretched, after which they will hold constant pressure. They were suggesting I use the old head gaskets for the initial startup as it really didn't matter what you used. Cardboard would work (they said) since you are just running it to temperature then shutting it down again. Of course, I did not save the original gaskets when I dismantled the two engines so I'll have to buy an extra two. Just another one of those tricks to remember when building engines. I'm sure Lycoming and Continental engine rebuilders have their own tricks. By the way, the block was decked to true the surface, and the cylinderheads were planed. I know that at least initially, I'll have two flat surfaces to mate together. The great majority of the Ford auto conversions have run reliably IF (the big IF) the builder followed the conversion manual and information that has accumulated. Corky Scott |
Engine weights | Salem Farm & Garden | Home Built | 5 | July 22nd 03 04:27 AM |
Gasflow of VW engine | Veeduber | Home Built | 4 | July 14th 03 08:06 AM |
Continental A65 engine | Philippe Vessaire | Home Built | 0 | July 10th 03 05:49 PM |
mercedes engine | Joa | Home Built | 1 | July 8th 03 12:26 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
