climb above the class b? i wouldnt, there is a lot of high speed traffic
up there. Baloney. All that "high speed traffic" is either taking off or landing (way down below you) or is overflying waaaayyy above you at 11.5 or 12.5. Overflying is the safest place to be. The view is great as well (assuming good weather) Been there, done that David Johnson |
![]() "David Johnson" wrote in message om... climb above the class b? i wouldnt, there is a lot of high speed traffic up there. Baloney. All that "high speed traffic" is either taking off or landing (way down below you) or is overflying waaaayyy above you at 11.5 or 12.5. Overflying is the safest place to be. The view is great as well (assuming good weather) Been there, done that David Johnson sorry but i have to disagree. flying over the top of ohare is not a good place to be. if you dont believe me check out the STARs, most have the inbounds crossing various fixes at 30 to 40 miles out at 11,000 ft. tony zambon grumman 9941L |
![]() sorry but i have to disagree. flying over the top of ohare is not a good place to be. if you dont believe me check out the STARs, most have the inbounds crossing various fixes at 30 to 40 miles out at 11,000 ft. I've been flying VFR over the top of O'Hare for the past 20 years. Almost no traffic up there. I find all of the traffic below 10,000' and above 4000' around the sides of the class B. But then again, I transition over the top in excess of 250 knots. For slower VFR, I'd recommend lake shore or the west side as previous posts have described. VL |
I have flown the low altitude route as well as over the top VFR and much
prefer the high altitude. If you have an engine problem you have a lot more options, and traffic is a lot more visible up high. Don't forget that all of the heavy iron has TCAS and will see you on the screen well before you see them. |
Negative XPDR - under the outer ring of Class C | bcjames | Piloting | 8 | August 30th 04 11:49 PM |
Run-in with Chicago Center | Jay Honeck | Piloting | 93 | August 24th 04 04:53 PM |
Overlapping class C & D | Andrew Sarangan | Piloting | 14 | May 6th 04 04:08 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
