On Thu, 16 Sep 2004 22:16:31 -0400, "Morgans"
wrote: "john smith" wrote in message . .. If I go a few degrees lower, the engine sputters. Do you have GAMI injectors? If not, "Thou shalt not run LOP!" Follow engine manufacture's instructions, if you can't get down to their Max CHT's. I strongly agree. If you cannot reach lean of peak without having the engine run rough, then don't. Because of your particular fuel/air distribution situation, it appears you will have to run rich of peak at all times in order to achieve smooth running. I suggest you lean to peak and then richen for the POH suggested temps and just accept the higher fuel burn than running lean of peak offers. It's not good to be running CHT's higher than 400F. It's not great to be running even that high, you should try to keep them under 400F. This is all spelled out in minute detail in John Deakin's AVweb column "Mixture Magic". See below. http://www.avweb.com/news/columns/182084-1.html Corky Scott |
Mogas: what happens to EGTs? | Stu Gotts | Owning | 21 | March 10th 04 03:21 PM |
