In rec.aviation.owning Stefan wrote:
wrote: Now granted these are turbojets, not turboprops, but it appears to me that making small turbines is possible... Nobody ever said that it's not possible. It's just not economical and will never be. Stefan Several people have said that but I've yet to see any analysis (with numbers) to back up that contention. Since (current) turbines are terribly inefficient at low throttle, I can see the problem with an aircraft that spends most of the time doing touch and goes. But where is the crossover point as dictated by the physics of turbines? C-182? C-209? Caravan? Whoops, that last one is already a turbine. -- Jim Pennino Remove -spam-sux to reply. |
About the size of the Caravan 900hp+
Mike MU-2 wrote in message ... In rec.aviation.owning Stefan wrote: wrote: Now granted these are turbojets, not turboprops, but it appears to me that making small turbines is possible... Nobody ever said that it's not possible. It's just not economical and will never be. Stefan Several people have said that but I've yet to see any analysis (with numbers) to back up that contention. Since (current) turbines are terribly inefficient at low throttle, I can see the problem with an aircraft that spends most of the time doing touch and goes. But where is the crossover point as dictated by the physics of turbines? C-182? C-209? Caravan? Whoops, that last one is already a turbine. -- Jim Pennino Remove -spam-sux to reply. |
In rec.aviation.owning Mike Rapoport wrote:
About the size of the Caravan 900hp+ Mike MU-2 According to the Cessna website, the current Caravan is 675hp. -- Jim Pennino Remove -spam-sux to reply. |
The Caravan has a 940hp engine flat rated to 675hp. Turbines are typically
flat rated so that the engine can make rated power to reasonable altitudes and temperatures without having to design the gearbox for the full thermodynamic horsepower. To keep the comparison with piston engines apples to apples you need to use thermodynamic ratings. http://www.pwc.ca/en/3_0/3_0http://w.../3_0_2_1_2.asp To put some numbers on things, the engines in my MU-2 have a specific fuel consumption of .55lb/hp/hr and a piston engine is about .45 and diesels can be under .40. Huge (ship) diesels can be under .30. Compare your model aircraft engines with the TFE731-60 used on the Falcon 900EX which uses ..405lb/lb thrust/hr Mike MU-2 wrote in message ... In rec.aviation.owning Mike Rapoport wrote: About the size of the Caravan 900hp+ Mike MU-2 According to the Cessna website, the current Caravan is 675hp. -- Jim Pennino Remove -spam-sux to reply. |
Mike,
TCM IO-520/550's running LOP are about .39-.40 BPSC according to the GAMI folks, the SEMA engine is about .33-.35 from their specs. At 70K for their engine conversion and the cost of JetA being within 10% of the cost of 100LL at most GA airports I ageree with you and don't think we'll see a lot diesel's in the near future. The Diamond Twin really impresses me, can' t wait for an independent (non-Flying or other slick mag) pilot report to see how it really does. Ernie BE36 E-160 KDVO "Mike Rapoport" wrote in message k.net... The Caravan has a 940hp engine flat rated to 675hp. Turbines are typically flat rated so that the engine can make rated power to reasonable altitudes and temperatures without having to design the gearbox for the full thermodynamic horsepower. To keep the comparison with piston engines apples to apples you need to use thermodynamic ratings. http://www.pwc.ca/en/3_0/3_0http://w.../3_0_2_1_2.asp To put some numbers on things, the engines in my MU-2 have a specific fuel consumption of .55lb/hp/hr and a piston engine is about .45 and diesels can be under .40. Huge (ship) diesels can be under .30. Compare your model aircraft engines with the TFE731-60 used on the Falcon 900EX which uses .405lb/lb thrust/hr Mike MU-2 wrote in message ... In rec.aviation.owning Mike Rapoport wrote: About the size of the Caravan 900hp+ Mike MU-2 According to the Cessna website, the current Caravan is 675hp. -- Jim Pennino Remove -spam-sux to reply. |
![]() "Ernie Ganas" wrote The Diamond Twin really impresses me, can' t wait for an independent (non-Flying or other slick mag) pilot report to see how it really does. Ernie I hope they have a better single engine service ceiling than what they were claiming during prototyping. I can't remember, but AIRC, it was less than 3 thousand feet. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.766 / Virus Database: 513 - Release Date: 9/17/2004 |
Morgans,
I can't remember, but AIRC, it was less than 3 thousand feet. http://www.diamond-air.at/en/products/DA42/facts.htm FL180. But anything to bad-mouth a product not from the USofA, right? -- Thomas Borchert (EDDH) |
![]() wrote in message ... In rec.aviation.owning Mike Rapoport wrote: About the size of the Caravan 900hp+ Mike MU-2 According to the Cessna website, the current Caravan is 675hp. -- Jim Pennino What is the useful load left over of a Caravan, after you fuel it for a 900 NM plus reserves trip? Oh, also, how about stopping the cross posting. Pick one. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.762 / Virus Database: 510 - Release Date: 9/13/2004 |
