#61
Roy Smith wrote:
It is certainly possible to build much larger piston engines than that. How about http://www.bath.ac.uk/~ccsshb/12cyl/ Ah! I've always wondered how that Antonov 225 Mrija was powered... Stefan |
#62
"Paul Sengupta" wrote in message
... Turbines do suffer from manufacturing defects (if I recall, there was an uncontained failure in the 90's on some rear-engine jet -- 727, DC-9 or something like that -- where the blade failure was due to some metallurgical problem). Sioux City DC10. Not actually the accident I'm thinking of. But yes, that's another example of blade failure (did they eventually determine it was a manufacturing defect, or a maintenance problem?). The accident to which I was referring only involved one or two fatalities, of a passenger or of passengers sitting right next to the engine. Pete |
#63
I believe you are referring to a Delta MD-80/88 that
was taking off from Pensacola. I think there were two killed and a couple of injuries. Mike Pvt/IFT N44979 PA28-181 at RYY Peter Duniho wrote: "Paul Sengupta" wrote in message ... Turbines do suffer from manufacturing defects (if I recall, there was an uncontained failure in the 90's on some rear-engine jet -- 727, DC-9 or something like that -- where the blade failure was due to some metallurgical problem). Sioux City DC10. Not actually the accident I'm thinking of. But yes, that's another example of blade failure (did they eventually determine it was a manufacturing defect, or a maintenance problem?). The accident to which I was referring only involved one or two fatalities, of a passenger or of passengers sitting right next to the engine. Pete |
#64
"Peter Duniho" writes:
Not actually the accident I'm thinking of. But yes, that's another example of blade failure (did they eventually determine it was a manufacturing defect, or a maintenance problem?). The accident to which I was referring only involved one or two fatalities, of a passenger or of passengers sitting right next to the engine. I recall it as well. DC-9, I believe... -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
#65
Mike H writes:
I believe you are referring to a Delta MD-80/88 that was taking off from Pensacola. I think there were two killed and a couple of injuries. http://www.ntsb.gov/ntsb/brief.asp?e...08X06203&key=1 -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
#66
Mike,
TCM IO-520/550's running LOP are about .39-.40 BPSC according to the GAMI folks, the SEMA engine is about .33-.35 from their specs. At 70K for their engine conversion and the cost of JetA being within 10% of the cost of 100LL at most GA airports I ageree with you and don't think we'll see a lot diesel's in the near future. The Diamond Twin really impresses me, can' t wait for an independent (non-Flying or other slick mag) pilot report to see how it really does. Ernie BE36 E-160 KDVO "Mike Rapoport" wrote in message k.net... The Caravan has a 940hp engine flat rated to 675hp. Turbines are typically flat rated so that the engine can make rated power to reasonable altitudes and temperatures without having to design the gearbox for the full thermodynamic horsepower. To keep the comparison with piston engines apples to apples you need to use thermodynamic ratings. http://www.pwc.ca/en/3_0/3_0http://w.../3_0_2_1_2.asp To put some numbers on things, the engines in my MU-2 have a specific fuel consumption of .55lb/hp/hr and a piston engine is about .45 and diesels can be under .40. Huge (ship) diesels can be under .30. Compare your model aircraft engines with the TFE731-60 used on the Falcon 900EX which uses .405lb/lb thrust/hr Mike MU-2 wrote in message ... In rec.aviation.owning Mike Rapoport wrote: About the size of the Caravan 900hp+ Mike MU-2 According to the Cessna website, the current Caravan is 675hp. -- Jim Pennino Remove -spam-sux to reply. |
#67
... "Paul Sengupta" wrote in message ... Turbines do suffer from manufacturing defects (if I recall, there was an uncontained failure in the 90's on some rear-engine jet -- 727, DC-9 or something like that -- where the blade failure was due to some metallurgical problem). Sioux City DC10. Not actually the accident I'm thinking of. But yes, that's another example of blade failure (did they eventually determine it was a manufacturing defect, or a maintenance problem?). They say it was a manufacturing defect about the size of a grain of sand. http://www.ntsb.gov/speeches/former/hall/jh970912.htm "Metallurgical examination of the titanium fan hub revealed that a fatigue crack originated from an inclusion near the surface of the hub's bore. The inclusion had been formed during the titanium vacuum-melting process at the time of manufacture about 2 decades earlier, which developed an internal cavity during final machining and/or shot peening. At the time of manufacture, the fan hub had been ultrasonic and macroetch inspected." The accident to which I was referring only involved one or two fatalities, of a passenger or of passengers sitting right next to the engine. Yes, I know the one you're talking about. It's mentioned on the page referenced above: "We will soon conclude our investigation on that Delta Air Lines MD-88 engine failure I mentioned earlier. Metallurgical examination of the fracture surface of that fan hub revealed that a fatigue crack had originated from a machining defect in a tie rod hole. Further, the fan hub had been fluorescent particle inspected only seven months before the failure, when the crack was estimated to be approximately ½-inch long." Also http://www.ntsb.gov/pressrel/1998/980113d.htm Paul |
#68
![]() "Ernie Ganas" wrote The Diamond Twin really impresses me, can' t wait for an independent (non-Flying or other slick mag) pilot report to see how it really does. Ernie I hope they have a better single engine service ceiling than what they were claiming during prototyping. I can't remember, but AIRC, it was less than 3 thousand feet. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.766 / Virus Database: 513 - Release Date: 9/17/2004 |
#69
Morgans,
I can't remember, but AIRC, it was less than 3 thousand feet. http://www.diamond-air.at/en/products/DA42/facts.htm FL180. But anything to bad-mouth a product not from the USofA, right? -- Thomas Borchert (EDDH) |
#70
![]() "Thomas Borchert" wrote in message ... Morgans, I can't remember, but AIRC, it was less than 3 thousand feet. http://www.diamond-air.at/en/products/DA42/facts.htm FL180. But anything to bad-mouth a product not from the USofA, right? He said single engine... Paul |
