![]() "Peter R." wrote in message ... Michael 182 wrote: Glad the chute worked, but what would cause an airplane to stall at 16,000 feet, then encounter turbulence that would send it into a spin at 15,000 feet? My take on the article, based on past news media aviation ignorance, is that the engine most likely quit at 16,000. I know we are all engaged in guesswork at this point, but if an engine fails at 16,000 feet I would expect that there is a nice long glide availble (regardless of turbulence) that would likely yield a pretty good landing spot. I know, I wasn't there - I'm not judging, just wondering... Michael |
Michael 182 wrote:
"Peter R." wrote in message ... Michael 182 wrote: Glad the chute worked, but what would cause an airplane to stall at 16,000 feet, then encounter turbulence that would send it into a spin at 15,000 feet? My take on the article, based on past news media aviation ignorance, is that the engine most likely quit at 16,000. I know we are all engaged in guesswork at this point, but if an engine fails at 16,000 feet I would expect that there is a nice long glide availble (regardless of turbulence) that would likely yield a pretty good landing spot. I know, I wasn't there - I'm not judging, just wondering... I totally agree with you. BTW, I am not speculating, just interpreting the article. ![]() -- Peter |
fails at 16,000 feet I would expect that there is a nice long glide availble (regardless of turbulence) that would likely yield a pretty good landing spot. I know, I wasn't there - I'm not judging, just wondering... Having just flown in that part of the world, I can safely say that an engine failure at 16K *might* only give you a couple of thousand feet to think about finding a landing spot, depending on the terrain. A long glide might not be in the cards. Worse, there were plenty of spots in the mountains where an engine failure would have been non-survivable. Unless, of course, you had a ballistic 'chute to deploy, like this guy did. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
http://www.duluthsuperior.com/mld/du...or/9723097.htm
I'm a bit concerned that I never heard about another recent deployment... "Still, the parachute system has not proven a cure-all, as evidenced by the Sept. 10 crash of a Cirrus SR22 in Park Falls, Wis. That crash claimed the life of Gerald Miller, 60, of Seboygan, Wis." It doesn't make clear whether the old fellow in Sheboygan deployed... |
("C Kingsbury" wrote)
snip What I'd wonder about, were I wealthy enough to have problems like this, is what about more marginal cases. Let's say I'm flying up here in densely populated New England, on top of an overcast at 4000' at night, and the engine quits. Let's say I've got 1500' ceilings. Do I pull the plug right away, or do I drop down through? How high do I have to be for the chute to open properly? Anything I can do to position myself so that the chute puts me down in that parking lot, rather than on I-95, or into some hospital building? From the Cirrus web page: http://www.cirrusdesign.com/servicec...ml/pohmain.asp (Same link as above) http://makeashorterlink.com/?T27445959 (I put you in an SR20. Hope that's ok) SR20 POH Section 3 - Emergency Procedures (randomly cut/pasted) Emergency Landing (Engine-out): Flaps Up................................................ ...................... ........86 KIAS Flaps 50%............................................... ...................... ......81 KIAS Flaps 100%.............................................. ...................... .....75 KIAS Maximum Glide Ratio ~ 10.9 : 1 .. Note . With a seized or failed engine, the distance that the airplane will glide will be more than the distance it would glide with the engine at idle, such as during training. If the propeller is windmilling, some additional glide range may be achieved by moving the Power Lever to idle and increasing airspeed by 5 to 10 knots. (Cirrus Airplane Parachute System - CAPS) The minimum demonstrated altitude loss for a CAPS deployment from a one-turn spin is 920 feet. Activation at higher altitudes provides enhanced safety margins for parachute recoveries. Do not waste time and altitude trying to recover from a spiral/spin before activating CAPS. (V-PD) Maximum Demonstrated Parachute Deployment Speed is the maximum speed at which parachute deployment has been demonstrated. The maximum demonstrated deployment speed is 135 KIAS. Reducing airspeed allows minimum parachute loads and prevents structural overload and possible parachute failure. Bon voyage :-) Montblack |
The FAA report gives the position of his last radio contact as 2 miles east
of Manteca. This is right in the middle of the California Central Valley - flat farm land, about 50' MSL that stretches uninterrupted north to south for more than 350 miles. It is probably the longest emergency landing strip west of the Rockies. There is no shortage of real airports either. I would assume that either the spin was not recoverable, or the pilot simply followed the instructions to use the BSR in the event of a spin. The real question is how you could get into a spin from turbulence in cruise flight in the first place. However, there were some mean thunderstorms in the area at the time (2" of rain fell in Sacramento earlier in the day and the weather was heading SW towards the accident area). Basically it was a mean cold front that swept through the area about the time of the accident- and it certainly wasn't forecast to be as wild as it turned out (wild by CA standards that is). I would think he more than likely got caught up in some of that convective activity. |
I just got thinking why would you be at 16,000' over the CA Central Valley ?
I like to fly high, normally 8,500' is my min altitude while, I'm flying XC around the state, but the oxygen requirements keep me below 12,500'. Even if I had oxygen on board - I would probably not use it until I had to get to altitude. For example, If you fly IFR than many of the MEA's over the mountains are going to force your to have oxygen. But say I was flying VFR, and I saw a line of CB ahead of me, I might be tempted to push it and try to climb over them. Maybe, there is already a layer underneath me so I can't get down to go underneath. Maybe, I just don't want to be under a big mean CB build-up when it looks like it tops out only a few thousand feet higher. Hopefully I have ox or maybe I figure I'll be "over the hump" before I'll really need it. Either way I start climbing. 16,000' and the plane really doesn't want to go any higher, I've maxed out the power, I'm pitched for best climb maybe a bit more and I'm still looking like I'll enter the top of the cloud. I starting to get worried, maybe I'm not IFR rated and anyway that is a mean CB cloud under me. I really don't want to be inside it. Without realizing it, I'm dangerously close to a stall. Maybe, I decide I've had enough and decide to do a 180, but as I turn, the plane stalls. I wasn't expecting it and before I know it I'm into the cloud getting kicked all over the place. Right about then I'd be really glad if I had a parachute. |
Brenor Brophy wrote:
I just got thinking why would you be at 16,000' over the CA Central Valley ? I like to fly high, normally 8,500' is my min altitude while, I'm flying XC around the state, but the oxygen requirements keep me below 12,500'. Even if I had oxygen on board - I would probably not use it until I had to get to altitude. For example, If you fly IFR than many of the MEA's over the mountains are going to force your to have oxygen. Here in the northeast US, there was a lot of thunderstorm activity this past summer. I fly a turbo Bonanza and when t-storms were in the forecast, I often chose an altitude in the mid-teens, despite having to suck on some O2, to have a better chance of spotting the build-ups above the haze and/or low layers. -- Peter |
Maybe the guy was laid off and/or unable to pay off the aircraft and did
this for the insurance???? or maybe it was a real emergency no one knows except for the person flying the airplane. I'd seriously be questioning his judgment from the news article! "Brenor Brophy" wrote in message .. . The FAA report gives the position of his last radio contact as 2 miles east of Manteca. This is right in the middle of the California Central Valley - flat farm land, about 50' MSL that stretches uninterrupted north to south for more than 350 miles. It is probably the longest emergency landing strip west of the Rockies. There is no shortage of real airports either. I would assume that either the spin was not recoverable, or the pilot simply followed the instructions to use the BSR in the event of a spin. The real question is how you could get into a spin from turbulence in cruise flight in the first place. However, there were some mean thunderstorms in the area at the time (2" of rain fell in Sacramento earlier in the day and the weather was heading SW towards the accident area). Basically it was a mean cold front that swept through the area about the time of the accident- and it certainly wasn't forecast to be as wild as it turned out (wild by CA standards that is). I would think he more than likely got caught up in some of that convective activity. |
Cirrus Deploys Chute Safely | m alexander | Home Built | 40 | September 28th 04 12:09 AM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
Another Cirrus BRS deployment: | Dan Luke | Piloting | 111 | April 19th 04 04:34 AM |
Cirrus BRS deployment | Dan Luke | Piloting | 37 | April 14th 04 02:28 PM |
New Cessna panel | C J Campbell | Owning | 48 | October 24th 03 04:43 PM |
