Best sunglasses for flying?
Old September 22nd 04, 06:48 AM
Jon Kraus
I don't know the technical reasons for this. I just remember reading it
somewhere. I think that most of the "pilot" sunglasses you will see are
Non-polarized.
Jon Kraus
PP-ASEL-IA
Student Mooney purchaser
Bryan Mason bmason wrote:
On Tue, 21 Sep 2004 22:45:00 GMT, Jon Kraus
Get whatever you want but make sure that you get Non-polorized lenses.
It makes seeing your instruments easier.
Why is this? I know that polarized lenses cause weird problems with
LCD panels, but how do polarized lenses make the aircraft instruments
harder to see?
-- Bryan
Old September 22nd 04, 10:37 AM
Bushy
harder to see?
Some of the instruments have polarised glass themselves. Some glass will
reflect polarised light at certain angles. Some angles of flight will cause
the windows of the aircraft to admit polarised light into the aircraft. If
the two lens are lined up in front of each other, the result is the same as
when you hold up two pairs of polarised sunglasses and look through both.
Rotate one of the pairs through 360 degrees and watch what you see. At
certain angles they will almost totally block the view. This causes the
affected instrument face to go black.
When you are trying to read your instruments with the sun at the same angle
as your instruments, you don't want to loose your view of the air speed
indicator!
Hope this helps,
Peter
Old September 22nd 04, 03:17 PM
Aaron Coolidge
: Some of the instruments have polarised glass themselves. Some glass will
snip
In addition the lexan/polycarbonate windows of aircraft have a polarizing
effect of they are under any amount of strain.
Aaron C.
Old September 22nd 04, 03:57 PM
Marco Leon
Case in point: JPI Engine monitors. I thought it was inop in a friend's
plane until I took off my polarized sunglasses.
Marco
"Aaron Coolidge" wrote in message
snip
Aaron C.
Generic Serengeti Driver sunglasses? (Bring in the Clones?) Mark General Aviation 1 October 9th 04 11:25 PM
Best sunglasses for flying? xyzzy Owning 22 October 2nd 04 02:29 PM
FS: Sunglasses you need Great Deal Aviation Marketplace 0 October 10th 03 04:51 AM
