![]() "Michael Houghton" wrote in message ... Howdy! In article , C J Campbell wrote: [snip] Who says I am anti-Cirrus? The Cirrus manual says the airplane cannot recover from a spin except by deploying CAPS. Is Cirrus anti-Cirrus? The following was quoted elsewhere in the thread: (Cirrus Airplane Parachute System - CAPS) The minimum demonstrated altitude loss for a CAPS deployment from a one-turn spin is 920 feet. Activation at higher altitudes provides enhanced safety margins for parachute recoveries. Do not waste time and altitude trying to recover from a spiral/spin before activating CAPS. This does not say "don't even thing of trying". It notes the need for prompt action at lower altitudes. If one is two miles up, one can take a moment to try to recover and still have room to deploy. Pray cite exactly where, in the Cirrus manual, it says that a spin is irrecoverable without using CAPS? Until you can back up your peculiar claim, you are trying to blow smoke up our posterior orifices, and that dog don't hunt. I would never think of blowing smoke up your particular orifice, Michael. The following was quoted elsewhere on the thread: "Spins The SR22 is not approved for spins, and has not been tested or certified for spin recovery characteristics. The only approved and demonstrated method of spin recovery is activation of the Cirrus Airframe Parachute System (See CAPS Deployment, this section). Because of this, if the aircraft “departs controlled flight,” the CAPS must be deployed." Now, Mr. Ferguson is the only person who has been kind enough to point out that this may be outdated (though not without being rather abusive about it), but it is still on Cirrus' web site and it remains the best official information that I have. If you clowns want to argue that the pilot in this case should not have followed the instructions in his flight manual then I guess I really don't know what to say, other than that I think you are idiots. I would be happy to go up with anyone in his Cirrus and we can see if it will recover from a spin without CAPS. |
"C J Campbell" wrote in message
... "Spins The SR22 is not approved for spins, and has not been tested or certified for spin recovery characteristics. The only approved and demonstrated method of spin recovery is activation of the Cirrus Airframe Parachute System (See CAPS Deployment, this section). Because of this, if the aircraft "departs controlled flight," the CAPS must be deployed." I figure that's like saying "The maximum demonstrated crosswind is 17 knots. Because if this, you must not land in crosswinds of greater than 17 knots". Ok, there's the "must not" bit and the "approved bit" but saying "Don't do it" is not the same as saying it can't be done. There's been a big debate about the spin characteristics of my plane, the Scottish Aviation Bulldog. It can get into a mode where it is very difficult to recover using "normal" or "recommended" techniques. It was found by one of the former British aerobatic champions that giving a blip of throttle made the plane recover from this type of spin pretty much immediately. A large outcry followed saying this wasn't approved technique and non-standard recoveries should not be attempted, etc. The RAF "thou shalt" if the plane got into this mode of spin was to jetison the canopy and jump out. Paul |
... "Spins The SR22 is not approved for spins, and has not been tested or certified for spin recovery characteristics. The only approved and demonstrated method of spin recovery is activation of the Cirrus Airframe Parachute System (See CAPS Deployment, this section). Because of this, if the aircraft "departs controlled flight," the CAPS must be deployed." OK, well, from the JAA certification testing: Results. The aircraft recovered within one turn in all cases examined. Recovery controls were to reduce power, neutralize ailerons, apply full rudder opposite to spin, and to apply immediate full forward (nose down) pitch control. Altitude loss from spin entry to recovery ranged from 1,200 to 1,800 feet. Detail results can be found in the above referenced reports. The "above referenced report" is a largish pdf file you can download from, among other places, the COPA website. -jav |
Cirrus Deploys Chute Safely | m alexander | Home Built | 40 | September 28th 04 12:09 AM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
Another Cirrus BRS deployment: | Dan Luke | Piloting | 111 | April 19th 04 04:34 AM |
Cirrus BRS deployment | Dan Luke | Piloting | 37 | April 14th 04 02:28 PM |
New Cessna panel | C J Campbell | Owning | 48 | October 24th 03 04:43 PM |
