we had cirrus open house come to salt lake city and give some local CFI's a
test ride - talked to the test pilots and it was the same. You get in a spin you pull the chute. Aircraft is not certified for spins (something about aft CG) I don't see the big deal - follow the POH. My question on the accident is what was a pilot doing up there that high above 12,500 did he have oxygen? Also he was close on the operation limits and if he was heavy (overloaded) he could have easily gone in a stall/spin including heavy turbulence..if I got in a spin yeah I *might* try and get out of the spin but I wouldn't waste time pulling that chute. in the end we'll just wait and see on the NTSB report (someone post it when it shows up) Matthew |
On Fri, 24 Sep 2004 16:07:51 GMT, "Matthew Chidester"
wrote: My question on the accident is what was a pilot doing up there that high above 12,500 did he have oxygen? Also he was close on the operation limits and if he was heavy (overloaded) he could have easily gone in a stall/spin including heavy turbulence. The 310hp SR-22 17,500 foot ceiling is a certified ceiling not a service ceiling. It is actually 500 feet less than the 200hp SR-20 ceiling, so I doubt that the problems with the plane were caused by being close to it climb limit. I don't know whether that plane had oxygen, but it is a factory option. |
![]() The 310hp SR-22 17,500 foot ceiling is a certified ceiling not a service ceiling. It is actually 500 feet less than the 200hp SR-20 ceiling, so I doubt that the problems with the plane were caused by being close to it climb limit. I don't know whether that plane had oxygen, but it is a factory option. huh I didn't know they had an option on oxygen - that's a LONG way down - interesting, well like I said should be an interesting NTSB report thanks for the info |
![]() "Matthew Chidester" wrote in message news:rDX4d.16430$He1.12412@attbi_s01... Also he was close on the operation limits and if he was heavy (overloaded) he could have easily gone in a stall/spin including heavy turbulence Why? He was (as has been pointed out in other posts in this thread) almost 3 miles AGL. If he was losing airspeed, point the nose down. Why would he stall? I've been in a lot of turbulence (I live on the Colorado Front Range) and it has never caused the airplane to come close to stall speed. Michael |
Michael 182 wrote:
"Matthew Chidester" wrote in message news:rDX4d.16430$He1.12412@attbi_s01... Also he was close on the operation limits and if he was heavy (overloaded) he could have easily gone in a stall/spin including heavy turbulence Why? He was (as has been pointed out in other posts in this thread) almost 3 miles AGL. If he was losing airspeed, point the nose down. Why would he stall? I've been in a lot of turbulence (I live on the Colorado Front Range) and it has never caused the airplane to come close to stall speed. Michael Well, I can't claim to have ever flown in severe turbulence, but my sense is not that the turbulence causes you to lose airspeed and stall, but that the correct way to handle this situation is to slow down enough that you are likely to stall if a gust is severe enough to stress the airframe. That's not to suggest that you want to end up in a spin, but it seems preferable to stall and spin at altitude then to have parts of the plane get ripped off. If I'm in a thunderstorm I'm going to make sure my airspeed stays below Va. -- David Rind |
exactly you're in a climb for some reason and heavy turbulence hits - woops
late response wrong rudder input you could do it.. not likely but i've flown and climbing at vx or even vy and you hit a gust, stall alarm goes and if you are THAT high - on a hot day you could get in a stall (I think anyway) |
Cirrus Deploys Chute Safely | m alexander | Home Built | 40 | September 28th 04 12:09 AM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
Another Cirrus BRS deployment: | Dan Luke | Piloting | 111 | April 19th 04 04:34 AM |
Cirrus BRS deployment | Dan Luke | Piloting | 37 | April 14th 04 02:28 PM |
New Cessna panel | C J Campbell | Owning | 48 | October 24th 03 04:43 PM |
