Hi Roger,
I then turned the mixture back to about 150 degrees ROP. The engine was perfectly smooth. This is the way I used to fly it and the way I know many pilots fly these planes. If I didn't look for or ignored the lack of RPM rise in ground leaning, I could fly it this way for months or years without suspecting there was a problem. From this experience, I conclude that many or most engines out there actually have minor induction leaks. This might also be part of the reluctance of manufactures and shops to recommend LOP operation. LOP any minor air leakage in the numerous hoses and joints of the induction system will be a "problem" and something wrong with the engine. ROP, minor leaks are not an issue and do not reflect on either the builder or the repair shop. Not until the engine suffers major damage due to one or more cylinders running not quite as rich and therefore hotter as the pilot thinks they do! Because this is what induction leaks and subsequent uneven mixture distribution does. If your engine starts to shake before even reaching peak EGT (mean), it can be concluded, that at least one cylinder is running significantly left of peak under these conditions. The same cylinder will, when operating the engine rich, be much closer to peak EGT than the overall mixture. (Lycoming would, based on findings of signs of overtemperature, probably blame the damage on lean operation, though...) I want my engine to run right and I now add to the list of LOP advantages the fact that any problems with the engine will become apparent early. good point! This is especially important to those of us who must fly without and engine analyzer. ...where you wouldn't notice high CHT on just one cylinder, exactly! regards, Friedrich -- for personal email please remove "entfernen" from my adress |
| Thread Tools | |
| Display Modes | |
| ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 08:36 PM |
| Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 07:42 PM |
| Rotax 582 engine problems | L. Darte | Home Built | 6 | May 9th 04 02:49 AM |
| Emergency Procedures | RD | Piloting | 13 | April 11th 04 09:25 PM |
| Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 05:29 AM |
