On Thu, 24 Jul 2003 10:58:15 -0500, John Thompson
wrote: Corky, I think one of the biggest roadblocks in autoconversions is the lack of "cookbooks". Instructions that cover things like that "stud stretching" tip, why you might want to use this camshaft, or replace this part or other, lifter bearing replacement, etc. and where to get them. I'm mechanically competent, but I've never done serious work on a auto engine beyong the shade tree stuff or replacing plugs, oil, hoses, etc. I can tear down and rebuild a small gas engine no problem, but there are a lot of little things that make big differences between a Briggs and Stratton, and a ford V-6. John You are actually echoing something I've been saying in this newsgroup for a long time: Building up your own auto conversion isn't for everyone and one of the biggest problems is the lack of compiled information. There actually are some published manuals for the Ford. One of them is written by Richard Finch. There was also a group of newsletters written by David Blanton while the engine was in the early use stage. These were important because there was a period of discovery going on after the actual plans for the engine and PSRU were maketed. Things were still happening to the engine that had not been anticipated and everyone sort of dealt with them in different ways. However, David Blanton was his own worst enemy. He was combative in the extreme, very defensive, obdurate and sometimes ***wrong***. He for instance misscalculated how much horsepower the engine would develop, and refused to listen to anyone about the situation. This, even when properly calculated dyno runs produced very respectible power readings. But he became the butt of many jokes when he insisted that his engines routinely put out over 240 horsepower and much more at only 4,800 rpm. They weren't. A well built 3.8L engine will usually make at least 180 hp, with many getting another 10 with minor modifications. One guy got 235 hp but he was willing to rev it to 5300 rpm to do that. He'd put racing connecting rods and pistons in it to withstand that rpm, which isn't high compared to racing standards. But I digress, there is also much useful information to be gleaned from Bruce Frank's Ford 3.8L STOL newsletter, but the specific engine information is spread out over a number of years and issues. Part of the problem is that there remain a LOT of solutions for various issues. For instance ignition: dual or single? How do you trigger it? Many are going with dual ignition with the second ignition running off an isolated battery. Some rig their ignitions to run dual all the time, others want to switch from one to the other. Still others trust one single source. You can trigger the ignition either using a distributer with dual pickups, a distributer with a single pickup and another pickup off the flywheel or crankshaft damper, or have both pickups sensed remotely off the crank somewhere. Then there's the engine itself. It's been modified by Ford over the years since it's intruduction. It's grown to 4.2 liters now and doesn't have a manifold that works for carburation anymo it's strickly an air manifold, not fuel/air. Also the lifters have gone from simple standard type lifters to roller lifters. The latest castings do not have a provision for a distributer. Some of the engines have the dual balance shafts, some don't. Then there's Jerry Schweitzer who used to build these engines for the homebuilt community, for all I know, he still may. He put out a video of what he thought was important and a lot of the information is really good stuff. For instance, he talked about drilling and tapping a hole through the intake manifold into the block where a coolant passage is. This is done on both sides. Then a pipe fitting is threaded in and the tubing routed back to another pipe fitting on the suction side of the water pump housing. What this does, he says, is draw off the "bubble" of air that always seems to form in the block/cylinderhead and tends to stay there causing the cylinderhead to improperly flow coolant. There are other things like an air/antifreeze seperator that needs to sit above the engine on the firewall that is pretty much standard on all auto conversions. Then there's the issue of a heater for the cockpit. One of the blessings of using a liquid cooled engine is that it can give you LOTS of heat with absolutely no danger of carbon monoxide poisoning. But the manner in which it is installed is different in just about every conversion. Some guys use it in such a manner that it helps the engine cool by routing coolant through it and dumping the airflow outside the cockpit. If heat is desired, they shut off the flow to the outside and the air blows into the cockpit. An awful lot of this depends on how you've built your airplane and how much room you have. For a look at how to build an auto conversion REALLY cheaply, you should get the Reverend Ron Van der Hart videos. The guy's kick and FAR more entertaining than Schweitzer and he's very talented to boot. Corky Scott |
Engine weights | Salem Farm & Garden | Home Built | 5 | July 22nd 03 04:27 AM |
Gasflow of VW engine | Veeduber | Home Built | 4 | July 14th 03 08:06 AM |
Continental A65 engine | Philippe Vessaire | Home Built | 0 | July 10th 03 05:49 PM |
mercedes engine | Joa | Home Built | 1 | July 8th 03 12:26 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
