Chris wrote:
How do aircraft manufactures determine the maximum gross weight for a given plane? I know I've come across articles that mention on a cool day you can go over the max. gross weight by a percentage, I think 20% was thrown out there but not sure. Then again, on a hot day you might not get any where near that. Is it determined by a standard temp? Which articles suggest it is OK to fly a plane over gross? |
"John Harlow" wrote in message ...
Chris wrote: How do aircraft manufactures determine the maximum gross weight for a given plane? I know I've come across articles that mention on a cool day you can go over the max. gross weight by a percentage, I think 20% was thrown out there but not sure. Then again, on a hot day you might not get any where near that. Is it determined by a standard temp? Which articles suggest it is OK to fly a plane over gross? AC 21-4b special flight permits for operation of overwieght aircraft for one example. I do believe there is are waivers for operations in Alaska and for operations with floats as well but I haven't found the documentation to prove it. That being said and having spent 10 years involved in aircraft design I can easily say that Manufactuers determine Gross weight based on a number of factors. Primarly the limiting factors are minimum aircraft performance, Cost and Reasonable aircraft Structures. Many times the Gross Wieght is determined by the Maximum allowable stall speed for the aircraft. Say I were to design a 1000 lb airplane stressed for acrobatics (6G's). Lets say the wings weigh 200 lbs so the non lifting weight is 800lbs. To redesign this same airplane into a Less than Normal Category airplane(just for easy numbers) (3G's) all I have to do is change the manual to limit it to 3g's and I can double the non-lifting weight of the aircraft so the new Gross wieght becomes 1800lbs. Likely the only part of the aircraft that has not been designed to handle 1800 lbs at 3G's is the landing Gear which was designed for only 1000lbs on the ground and for landing. Of course the take off and landing distances will increase with the new gross weight as will nearly all performance speed except Vne. Common Myths: Aircraft are required to be designed to 1 -1/2 times the rated load, so there is lots of safety factor built in. Actually: All that is required is that aircraft be designed to repeatly handle the rated load without damaging the structure. Additionally the structure must not fail if subject to less then 1-1/2 times the rated load, However the strucure may be damaged if the rated load is exceeded. Wo if I take my aluminum airplane rated at 6G's and do an 8G pull out the wings will probably not fall off. However it will probably bend the wings and leave them permantly bent. I have seen a C-182 that this happened to. Aluminum makes a great material for aircraft because it complies almost exactly to the regulation. You can load it up to the limit load with no permanent damage. And you can load it up to the ultimate load without it breaking however it will permanently bend it. Myth#2. Manufactures overbuild the aircraft. Actually: a former Cessna Engineer told me that the way they designed a structure was they would have the engineer design the structure they would then load test it. If the structure did not fail on the 1st test they fired the engineer for overbuilding it. After it failed the reeinfored the area that failed and tested it again. They would repeat this process until the structure just barely passed. Every lb the manufacturer could take off of the airplane is 1 more lb of performance they could sell and 1 lb less of material they had to buy. Cessna didn't paint their airplanes for years in order to save the weight of the paint. The only reason they changed is they could no longer get consistantly unscratched aluminum to work with. Brian |
Apache Alternate Gross Weight | Jim Burns | Owning | 1 | July 6th 04 05:15 PM |
Dutch Roll | SelwayKid | Piloting | 31 | June 19th 04 11:43 PM |
homebuilt safety | anonymous coward | Home Built | 96 | June 3rd 04 04:34 AM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
F35 cost goes up. | Pat Carpenter | Military Aviation | 116 | April 11th 04 07:32 PM |
