#81
I think that you can look at the market to see where the crossover
occurs. THere are currently no production piston aircraft engines over 450hp and there are no aircraft turbines under 400hp. There's lots of ground turbines under 400hp so we know there's a market there; [...] A ground turbine runs at almost constant speed, near its design point, so even at small dimension can still be fuel efficient. Part load fuel consumption of a gas turbine is a bit too high, particularly for GA aircraft (considering their flight pprofile). -- Fritz |
#82
"Fritz" wrote in message
... A ground turbine runs at almost constant speed, near its design point, so even at small dimension can still be fuel efficient. Part load fuel consumption of a gas turbine is a bit too high, particularly for GA aircraft (considering their flight pprofile). Hmmm...define "fuel efficient"? Your comment brings to mind the Toyota Prius hybrid engine. It essentially has a "continuously variable transmission" that doesn't involve a complicated, maintenance-hungry belt or chain and pully system. I wonder if the answer to bringing turbine engines to small airplanes might not be using a hybrid system. The weight of the batteries (which is substantial) is offset by the relatively low weight of the rest of the power train. The engine would only run during climbs, and when the batteries need to be recharged. Biggest problem I see right off the bat is the problem of starting and stopping the turbine frequently...my understanding is that there are "issues" there, but I don't know what they are, or whether they can be addressed by design. Using such a system, a turbine could be run "at almost constant speed, near its design point", while accomodating a variety of power settings. All that said, someone else mentioned turbine-engined locomotives; that's a much bigger power demand and yet somehow diesel-electric engines wound up the standard. I suppose looking at the history of train locomotives might offer some insight into how feasible hybrid technology might be for airplanes. It might be that there are some unsolveable problems, or it might be that we're at a stage in engine development now where things that used to be problems aren't anymore. Pete |
#83
Small turbines are inherently inefficient so you are unlikely to see them in
this power range. The fuel consumption might be double that of a diesel. It's not true, first off. Although bigger engines have advantages of Reynolds numbers and such, small and large are relative terms. The relationship of BSFC of heavy diesels and industrial gas turbines in steady state peak operation is pretty constant across engines from the size of an 855 cid Cummins to the really big guys with four foot bores. The turbocharged diesels are somewhat more efficient but nowhere near 2:1. The "secret" of linearizing gas turbine performance across a wide range of output power is thermal feedback, or regeneration. Look carefully at the real progenitor of the Cruise Missile turbojet... |
#84
#86
I don't disagree with you Dean on the spares issue etc., but as I see
it is you add up the cost of the engine and spares and then the fuel used over 40K hours or so and see where the real $ are. I also don't disagree about two different vintage engines; newer are more efficient, but look at the SFC on a CF6 of about 40K thrust and a CF34 of 9K thrust (same vintage) and I bet the larger engine has the upper hand; maybe not. Good discussion subject and it would be interesting to hear from others who know what they are talking about. Obviously anything I say comes from being around these things, not because I profess to be any kind of authority. Any aircraft turbine engineers out there? Neat thing about aviation is there is always something to be learned. |
#87
Firstly, all gas turbine rotors-compressor and turbine-are airfoils,
and that's why engine (and airframe) designs don't scale perfectly for aerodynamic performance: air, in effect, has a finite size. All engines are more efficient as the delta between the hot parts and the cold parts increases, per Carnot. That said the primary reason car engines run hotter than before is not because of direct thermal efficiency but for emissions and also because smaller radiators can be used. Large turbines are actually designed to wear themselves in at times as creepage brings the blades out and they ever so slightly lathe themselves down, opening up the stator surface as they do. Active clearance control using bleed air is another nifty feature of big engines. Working against the economics of big fan engines is the fan case being bigger than normal shipping means can handle. Also, a serious FOD, midair, or controller failure resulting in an engine writeoff is a much bigger capital hit:someone has to write a big check. The less the number of engines the greater probability that one engine will fail. However the consequence of one engine failing becomes directly higher. One engine out on a B-52 is a marginal consideration: one engine out on a single turns your mission to worst case recovery (find an airport, off airport landing, ditch, or bailout/eject depending on the aircraft and terrain underneath.) An exception to this rule is the light twin, most of which are really 1 1/2 engine airplanes to start with, and which tend to be flown by hobbyists and part-timers. Statistics show that engine failures in light twins kill more people than engine failures in singles, for a lot of reasons. Cessna, Piper, and Beech knew this since roughly 1960 and their response for 25 years was, buy more liability insurance. When high interest rates in 1986 made the reinsurance market for this untenable, "they could no longer make reciprocating-engine aircraft". ETOPS-Engines Turn Or People Swim! |
#88
Dean Wilkinson wrote:
The increased fuel efficiency of the 777 engines is not strictly due to their size. They are a newer generation design with very high bypass and advanced FADEC controllers. The 747 engines are an older design. Also, the 777 is a more aerodynamically efficient airplane than the 747. The other big advantage of two engines vs. 4 is cost of ownership in terms of maintenance and spares. Its less expensive to maintain two engines per plane than 4. Also, statistically speaking, the probability of an engine failure per flight hour is lower for the 777 than it is for the 747 since it has fewer engines to fail. Believe it or not... this was demonstrated to me when I worked at Boeing on the 777 development. True, but the probability of losing all of the engines at the same time is greater with only two engines as opposed to four. Matt |
#89
light twins kill more people than engine failures in singles, My understanding is that this statistic only applies to engine failures that result in accidents. Left out are all the twins that had engine failures and landed safely. |
#90
![]() True, but the probability of losing all of the engines at the same time is greater with only two engines as opposed to four. Matt Not necessarily... There has never been a historical case of a twin engine jetliner losing both engines at once due to unrelated failures. All twin engine failures have been due to a common cause; fuel starvation being the prime reason. Here are some examples of related engine failures: A four engine 747 had all four engines flame out at the same time when it flew into the ash cloud of Mt. Redoubt in Alaska, and only managed to restart three of them after losing over 10,000 feet of altitude. A four engine Airbus A340 made a dead-stick landing at Lajes in the Azores after running of fuel due to a combination fuel leak and fuel system management problem. A 767 (twin) made an emergency landing in Canada on a drag strip after losing both engines due to a miscalculation during fueling. The probability of an ETOPS plane losing both engines in a single flight due to unrelated failures is extremely remote. That doesn't mean it can never happen, but it is less likely than winning the lottery. |
