Philip Sondericker wrote: in article fT27d.3595$mS1.2578@fed1read05, BTIZ at wrote on 9/30/04 7:00 PM: that would be one heck of a thermal ride... if it weren't for the rocks... and "cough cough" the ash.. BT I was thinking about this recently, and I was trying to determine exactly what the effects would be on a small plane flying into an ash cloud. How long would it take for the air filter to become completely clogged? And at that point, assuming the plane had a carburetor, what would be the effect on the engine? Would the plugs become fouled? Would they fire at all? I'm a new pilot and relatively ignorant of engine operations, so I'm curious to hear the answers. You can count on an early overhaul, at best. During the 1980s, several turbine aircraft, including a B747, encountered ash clouds in flight. The ash is so abrasive that it eroded the compressors to the point of flameout. The B747 descended to ~10000 ft before they got three engines relit. A C130 had similar problems. In a piston engine, the alternate air door would probably open, allowing unfiltered air into the engine. I p-robably wouldn't atop, but the compression test would be pretty grim. |
Orval Fairbairn wrote:
You can count on an early overhaul, at best. During the 1980s, several turbine aircraft, including a B747, encountered ash clouds in flight. The ash is so abrasive that it eroded the compressors to the point of flameout. The B747 descended to ~10000 ft before they got three engines relit. June 24, 1982, a British Airways 747 over Java. The ash cloud also sandblasted the windshield nearly opague. The flight crew had great difficulty making out the approach and runway lights to land the aircraft. If the incident had occurred during daylight hours, they probably would not have been able to see out at all. |
"Philip Sondericker" wrote in message
... I was thinking about this recently, and I was trying to determine exactly what the effects would be on a small plane flying into an ash cloud. How long would it take for the air filter to become completely clogged? And at that point, assuming the plane had a carburetor, what would be the effect on the engine? Would the plugs become fouled? Would they fire at all? The Northwest Mountain Division has rearranged things, and I can't find their article anymore. But sometime back in the 90's, I read a description on their web site about some consequences of the St. Helens eruption in 1980. The description included a jet that suffered the failure of all engines, and a lightplane that barely survived. Here are some articles that address the turbine side of things: http://www.boeing.com/commercial/aer...nic_story.html http://www.nw.faa.gov/releases/volash.html I found them looking for the other article I remember. Anyway, I don't know how long it would take for the air filter to become clogged, but probably not too terribly long if you flew through the meat of an ash cloud. Obviously, it depends on how close you get to the densest part; just skim a side of the cloud, and you might not notice a problem at all. Go through the middle, and you might clog the filter in a matter of minutes. Of course, the next step at that point would be to use the alternate air; carb heat for carbureted engines, and whatever alternate air source for fuel-injected (often is an automatically deployed, spring-loaded door that bypasses the filter when it's clogged). One ingested, the ash would start eating up the engine, but I would guess that you'd at least have enough time to get on the ground to make an emergency landing. I think that the plugs getting fouled would be the least of your worries, but who knows? Maybe the heat of the spark would cause a nice, insulating glass barrier to form at the sparkplug gap. That is assuming, of course, you can still see out of the windows, since they'll have been sandblasted the whole time. And that you find an area of visibility high enough to make a landing. If the engine fails before you can land, then you obviously will be forced to land wherever you happen to be, regardless of whatever visibility you have. I gather that generally speaking, other than trashing the airplane, pilots usually make it out of ash clouds alive. But not all do, and it's certainly not something I'd want to try, given the option. ![]() Pete |
Philip Sondericker wrote in message ...
in article fT27d.3595$mS1.2578@fed1read05, BTIZ at wrote on 9/30/04 7:00 PM: that would be one heck of a thermal ride... if it weren't for the rocks... and "cough cough" the ash.. BT I was thinking about this recently, and I was trying to determine exactly what the effects would be on a small plane flying into an ash cloud. How long would it take for the air filter to become completely clogged? And at that point, assuming the plane had a carburetor, what would be the effect on the engine? Would the plugs become fouled? Would they fire at all? I'm a new pilot and relatively ignorant of engine operations, so I'm curious to hear the answers. The engine is about the last part I would worry about when flying through a vulcanic ash cloud. Probably you get burned to death or at least get a bit charred, together with your plane. To answer your quistion about the engine. It will end up ruined, either by crashing or by inhaling to much dust and then crashing. Or maybe you are lucky and you end up with a nice sandblasted aircraft. Some jets have flown through such clouds(they fly much higher, the cloud is cooler that high), they needed a repaint and have their engines replaced. -Kees |
in article fT27d.3595$mS1.2578@fed1read05, BTIZ at wrote on 9/30/04 7:00 PM: that would be one heck of a thermal ride... if it weren't for the rocks... and "cough cough" the ash.. BT I was thinking about this recently, and I was trying to determine exactly what the effects would be on a small plane flying into an ash cloud. How long would it take for the air filter to become completely clogged? And at that point, assuming the plane had a carburetor, what would be the effect on the engine? Would the plugs become fouled? Would they fire at all? Considering that a volcano almost brought down a 747 once, I don't think a small plane is going to last long at all. Of course, the pilot is going to have been broiled long before he has to worry about his engine. Rich Lemert |
![]() There are plenty of films of people driving around in the ash cloud. They are likely driving at ten percent power. Jose -- (for Email, make the obvious changes in my address) |
Which Military Service is best? | ArtKramr | Military Aviation | 33 | September 19th 04 04:12 PM |
