In rec.aviation.owning Dean Wilkinson wrote:
True, but the probability of losing all of the engines at the same time is greater with only two engines as opposed to four. Matt Not necessarily... There has never been a historical case of a twin engine jetliner losing both engines at once due to unrelated failures. All twin engine failures have been due to a common cause; fuel starvation being the prime reason. Here are some examples of related engine failures: A four engine 747 had all four engines flame out at the same time when it flew into the ash cloud of Mt. Redoubt in Alaska, and only managed to restart three of them after losing over 10,000 feet of altitude. A four engine Airbus A340 made a dead-stick landing at Lajes in the Azores after running of fuel due to a combination fuel leak and fuel system management problem. A 767 (twin) made an emergency landing in Canada on a drag strip after losing both engines due to a miscalculation during fueling. The probability of an ETOPS plane losing both engines in a single flight due to unrelated failures is extremely remote. That doesn't mean it can never happen, but it is less likely than winning the lottery. Not quite; the probability of all engines failing decreases with the number of engines if all engines have the same probability of failing. Whether or not this will actually happen is highly dependent on the probability of the individual engine failing. Since airline engines tend to be well maintained, and hence the probablity of failure low, one could reasonably say the chances of multiple engine failures (no common cause) is quite remote. However, a friend of mine that spent lots of time in B-52s relates the tale of the time they lost 3 engines (no common cause) during flight and a fourth engine on final getting "that big piece of crap" back on the ground. -- Jim Pennino Remove -spam-sux to reply. |
Jim,
Please don't reply in such a way as to make it appear that I said something that I did not. It was Matt Whiting that made the comment about losing all engines on a twin being more likely than losing all four. I didn't say that, and I know that is not true. Dean wrote in message ... In rec.aviation.owning Dean Wilkinson wrote: True, but the probability of losing all of the engines at the same time is greater with only two engines as opposed to four. Matt Not necessarily... There has never been a historical case of a twin engine jetliner losing both engines at once due to unrelated failures. All twin engine failures have been due to a common cause; fuel starvation being the prime reason. Here are some examples of related engine failures: A four engine 747 had all four engines flame out at the same time when it flew into the ash cloud of Mt. Redoubt in Alaska, and only managed to restart three of them after losing over 10,000 feet of altitude. A four engine Airbus A340 made a dead-stick landing at Lajes in the Azores after running of fuel due to a combination fuel leak and fuel system management problem. A 767 (twin) made an emergency landing in Canada on a drag strip after losing both engines due to a miscalculation during fueling. The probability of an ETOPS plane losing both engines in a single flight due to unrelated failures is extremely remote. That doesn't mean it can never happen, but it is less likely than winning the lottery. Not quite; the probability of all engines failing decreases with the number of engines if all engines have the same probability of failing. Whether or not this will actually happen is highly dependent on the probability of the individual engine failing. Since airline engines tend to be well maintained, and hence the probablity of failure low, one could reasonably say the chances of multiple engine failures (no common cause) is quite remote. However, a friend of mine that spent lots of time in B-52s relates the tale of the time they lost 3 engines (no common cause) during flight and a fourth engine on final getting "that big piece of crap" back on the ground. -- Jim Pennino Remove -spam-sux to reply. |
Jim, Please don't reply in such a way as to make it appear that I said something that I did not. It was Matt Whiting that made the comment about losing all engines on a twin being more likely than losing all four. I didn't say that, and I know that is not true. Ummm, I posted a followup to the entire post as received without editing any previous content. The depth of the '' characters at the beginning of the lines should show who said what and my response was to the latest post, i.e. that of Matt Whiting. -- Jim Pennino Remove -spam-sux to reply. |
Jim, Please don't reply in such a way as to make it appear that I said something that I did not. It was Matt Whiting that made the comment about losing all engines on a twin being more likely than losing all four. I didn't say that, and I know that is not true. How do you know this is not true? If I recall correctly, the probability of independent events occuring simultaneously is equal to the product of the probabilities of each event occurring. If we rule out common cause failures such as fuel exhaustion and look at only random failures, the the probability of all engines failing simultaneously is the product of the probability of failure of each engine separately. Assuming that each engine has the same probability of failure, means that with two engines the probability of both failing is P^2 whereas with four engines the probability of all failing is P^4. Since 0=P=1, P^4 will be less than P^2. As someone else said, the probability of having AN engine fail on any given flight is higher with more engines, but I believe the probability of ALL engines failing on a given flight is less with more engines. Matt |
Ernest Gann in "Fate is the Hunter" described one event in which he
lost nearly all power on 3 of 4 out of LGA once, and another time that all 4 quit simultaneously with a load of passengers over the Pacific. The first event was caused by the mechanics testing a new type of spark plug, which they "unfortunately" had time to install on 3 engines. The second was a glitch in the fuel system. |
In rec.aviation.owning Robert Briggs wrote:
wrote: Dean Wilkinson wrote: The probability of an ETOPS plane losing both engines in a single flight due to unrelated failures is extremely remote. That doesn't mean it can never happen, but it is less likely than winning the lottery. Not quite; the probability of all engines failing decreases with the number of engines if all engines have the same probability of failing. That looks fair enough at first sight, but, as you go on to say, it is "highly dependent on the probability of the individual engine failing". The whole point of ETOPS is that the *requirements* for the engines are rather stricter than those for airliners with three or more engines, since once you've got a single failure the other fan had jolly well better keep turning. With three or more engines, a second failure during diversion is much less likely to be catastrophic. Of course, if you take two pairs of ETOPS engines, fit them to a four-motor aeroplane, and maintain them to ETOPS standards then the probability of losing all of them from unrelated failures is exceedingly small - *way* down in the noise of multiple failures with a *common* cause. After posting it occured to me that the above was an incorrect statement. It should be, the probability of all engines failing decreases with the number of engines. While the probability of all engines failing will increase with the probabilities of individual enginge failure, that number will always be less than any individual probability. This is a consequence of the laws of probability and nothing else. In the real world, we attempt to keep those probability numbers low so that such an occurance becomes highly unlikely. The probability of getting 3 jackpots in a row on a Vegas slot machine is a number greater than zero, but does not form a valid basis for a retirement plan, for example. -- Jim Pennino Remove -spam-sux to reply. |
wrote: Robert Briggs wrote: The whole point of ETOPS is that the *requirements* for the engines are rather stricter than those for airliners with three or more engines, since once you've got a single failure the other fan had jolly well better keep turning. While the probability of all engines failing will increase with the probabilities of individual engine failure, that number will always be less than any individual probability. This is a consequence of the laws of probability and nothing else. There is more than simple "the laws of probability" at work here. In pre-ETOPS days, three or more engines were required for, say, transatlantic airliners because the risk of multiple engine failures was deemed to be too high. ETOPS certification requires engines which are *demonstrated* to be more reliable than those on 707s, early 747s, and the like. It is by no means impossible for four independent engine failures on an older aeroplane to be more likely than two on an ETOPS kite. Of course, now that manufacturers are building ETOPS-certified engines there's not a great deal of point in deliberately making *less reliable* versions for airliners with three or more engines, so it is rather likely that *newer* 747s are less prone to losing all four engines independently than twins are to losing both. Mathematics doesn't care about certifications or maintenance programs. Programs are based on the mathematics. If the probability of an engine failing is 0.1, the probabilities for all engines failing a 1 0.1 2 0.01 3 0.001 4 0.0001 If the probability of an engine failing is 0.7, i.e. really ratty engines, the probabilities for all engines failing a 1 0.7 2 0.49 3 0.34 4 0.24 Things like ETOPS exist because the numbers say getting the probabilities low is a good thing. -- Jim Pennino Remove -spam-sux to reply. |
![]() If the probability of an engine failing is 0.1, the probabilities for all engines failing a 1 0.1 2 0.01 3 0.001 4 0.0001 5: not enough information to say. You do not specify that the probability of an engine failing is independent of the other engines failing. Fly through a volcano cloud and I bet you'll find that if one engine fails, the others will too... quickly. Volcanos don't care about mathematics. Things like ETOPS exist because the numbers say getting the probabilities low is a good thing. True enough. For independent failurs, get the "one engine" number down low enough and the "two engine" number will also go down low enough. I'm sure they also address dependent systems in ETOPS land too, and want a dependent failure probability to be "low enough". Jose -- (for Email, make the obvious changes in my address) |
