First "real" hold (long)
Old October 4th 04, 11:07 PM
Chip Jones
"Roy Smith" wrote in message
"Dan Luke" wrote:
I suppose so. I always have this feeling my old CFII is sitting in the
right seat, shaking his head when I don't do something "by the book."
Single-pilot IFR is all about task prioritization. Take care of the
important stuff, and don't waste time on the **** that doesn't matter.
As long as you stay in the protected airspace, nobody cares what your
holds look like, or how perfectly timed the legs are.
From an ATC stand-point, most controllers certainly could care less what a
hold looks like when flown. Personally, I just want you to maintain
assigned altitude and meander in orbit somewhere over the fix in the general
direction assigned. We controllers get really conservative around holding
patterns, and a tightly-flown pattern really doesn't matter. Likely, no one
in ATC-land will even notice if you nail the turns and the times, because
they are looking at a lot of other stuff on the scope. The prudent
controller will be using vertical separation below and above your protected
airspace, and he/she will be adding a lot of extra lateral protection around
your bubble too, just in case.
Chip, ZTL
Old October 5th 04, 12:07 AM
Roy Smith
direction assigned.
One thing I have noticed is that while ATC doesn't seem to care much
about where you go on the holding side of the fix, if you meander just a
little bit PAST the holding fix, you're likely to get a call politely
enquiring if you have any idea where the hell you are.
Old October 5th 04, 03:45 PM
Newps
And unless you are in a charted holding pattern the idea of a protected
side and unprotected side is pretty funny too.
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
Flight test update - long nauga Home Built 1 June 5th 04 03:09 AM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 03:02 PM
IFR Long X/C and the Specter of Expectations David B. Cole Instrument Flight Rules 0 February 24th 04 07:51 PM
Long Range Spitfires??? ArtKramr Military Aviation 3 September 9th 03 10:05 PM
