Turbulence
Old October 8th 04, 03:12 PM
Marco Rispoli
Default Turbulence
One of the things that TERRIFIED me for the longest time was turbulence.
In fact, the very reason why my wife bought me a "Discovery Flight" at the
very beginning (and got me hooked to flying) was to get me to see that there
was nothing to fear from planes, after me and her had a really bad (for me)
flight back from Italy.
Ok ... after a little less than 100 hours of flight I have had my dose of
turbulence in flight ... while at the controls of a plane.
It is reccommended that if you encounter turbulence you slow down below Va
(manouvering speed), so if you encounter an especially stiff gust the plane
will stall before pulling enough Gs to snap a wing. That's what the book
says ... and I used to follow it to the letter, to the point that even the
minimum turbulence would make me slow down to below Va.
I remember once, during a mock checkride with a senior instructor we
encountered some turbulence and I instinctively pulled the power to slow the
plane below Va.
The intructor's reaction was instantaneous and unyelding:
"The hell are you doin'?" (Heavy Staten Island accent).
"Slowing the plane below manouvering speed" I say, my tone of voice like
that of a guy that has just been asked why the sun comes up in the morning.
"Why?"
"Ah .. " I stammer surprised by the question ... isn't it obvious why?
"Because we are in turbulence?" it was supposed to be a statement but it
came out as a question ... a sheepish question at that.
The Instructor roars in laughter, for an instant louder than the engine.
"Dude, this is not turbulence. Put that power back in. I want to see that
needle at 2400 RPMs, in the RPM green arc." End of the argument.
It was light turbulence with occasional moderate. It was one of those cold
late winter days when winter is about to give up to spring but doesn't quite
like the idea ...
To me it felt like we were getting slammed. To him this wasn't even a
tickle. Obviously our concepts of turbulence differed dramatically.
So, question to the more seasoned and weathered pilots out the
If I am clear air (VFR), and I am not close to mountains (so I don't have to
worry about mountain waves), and I am flying around in my little cutie Piper
Cherokee 180 do I even need to worry about turbulence?
I am just about done reading Rod Machado's IFR book and the bottom line is
that you need to be inside a thunderstorm in order to start worrying about
turbulence. In most conditions, just flying around VFR in your everyday CAT
(Clear Air Turbulence) doesn't warrant fussing about it, and all you really
have to do is just stay in the green arc. That's all.
According to what the book is saying, only older planes really need to worry
about Va in moderate turbulence. Modern planes (certified after 69) can fly
right through it, as long as you stay in the green arc.
I don't plan to fly into thunderstorms any time soon ... so, do I even need
to worry about manouvering speed if I am just flying in one of those gusty
fall or spring Northeast VFR days?
Is staying below the green arc good enough?
Marco Rispoli - NJ, USA / PP-ASEL
My on-line aviation community - http://www.thepilotlounge.com
Old October 8th 04, 03:57 PM
Marc J. Zeitlin
To folks that haven't experienced a lot of turbulence, a little can seem
like a lot. I gave a ride to a COZY builder who had never been in a
small plane - he asked whether we were in moderate to severe turbulence
when I hadn't really even noticed that we had hit a tiny burble.
have to
Piper
Not really. I fly in the NE, like you do, and while I've experienced
mild to moderate turbulence down low on VFR days, I've never really
gotten hammered. Even when it __feels__ like I'm getting hammered, it's
still considered moderate - go look up the definition of severe
turbulence - basically, you can't control the plane.
need
gusty
Nope. If you can keep the plane upright, there's no issue.
You mean red? Below the green arc, I don't think the plane will stay in
the air :-). On my COZY (admittedly a homebuilt, but the concept is the
same) the red arc begins at 220 mph IAS and the yellow arc begins at 140
mph IAS. Va is 140 mph, but I NEVER fly that slow - usually I'm
cruising at about 175 - 180 mph IAS, no matter what the turbulence level
(I'm VFR only). The only thing I slow down for in cruise is if the
visibility sucks.
Marc J. Zeitlin
http://marc.zeitlin.home.comcast.net/
http://www.cozybuilders.org/
Copyright (c) 2004
Old October 8th 04, 04:04 PM
Marco Rispoli
the air :-).
Yea sorry. I meant below the yellow arc. Not below the green arc, but IN the
green arc.
Typo.
Thanks for the info!
Old October 8th 04, 04:42 PM
Mike Rapoport
If I am in an area where moderate or greater turbulence can be expected (or
is possible) like desending to an airport in mountainous terrain with the
wind howling, I slow down whether I am currently experiencing any turbulence
or not. If I am flying along below small cumulus and experiencing some
bumps, I don't slow down.
There is nothing wrong with slowing down if you are uncomfortable. I would
try to keep everything in the green arcs as much as possible though.
Mike
MU-2
"Marco Rispoli" wrote in message
et...
there
me)
plane
plane below Va.
morning.
"Why?"
quite
like the idea ...
to
Piper
CAT
really
worry
fly
need
Old October 8th 04, 06:19 PM
Gary Drescher
et...
plane
Minor correction: the wings snap due to excessive lift (force), not due to
excessive Gs (acceleration). Staying below Vne keeps the force from being
excessive; staying below Va keeps the acceleration from being excessive. Vne
does not vary with weight; Va varies in proportion to the square root of
gross weight, becoming a stricter limit when weight is lower. That's because
the less mass you have, the more acceleration is produced by a given force.
If you don't feel more than 2G upward acceleration (or 1G downward) in
turbulence, you're well within the acceleration design limits for a
normal-category airplane.
--Gary
Old October 8th 04, 07:19 PM
NW_PILOT
et...
there
me)
plane
plane below Va.
morning.
"Why?"
quite
like the idea ...
to
Piper
CAT
really
worry
fly
need
I wonder what setting them pilots use when flying in to hurricane's now that
has to be unsane and very turbulent.
Old October 8th 04, 08:01 PM
Peter Duniho
et...
to
Piper
I guess you have to define "worry".
If the air is bumpy, it always potentially could exceed the design limits of
the airplane. For that matter, you could be flying along in completely
smooth air and experience sudden and severe turbulence.
In that respect, you should *always* worry about turbulence. It's always
potentially there, and always potentially greater than the limits of the
airplane.
However, as others have mentioned, pilots, especially relatively
inexperienced ones, typically overestimate the strength of turbulence. It's
probably true that general bumpiness out in the open, away from severe
weather (includes strong winds) and terrain is probably going to be safe at
any normal cruise airspeed.
That said, "away from" is an ambiguous term. Terrain can still be quite far
away and still cause strong turbulence (50-100 miles or more in some cases).
Similarly, strong winds can seem trouble-free for long distances, but due to
wind shear result in very significant, isolated clear-air turbulence as you
fly through an area where there's another fast-moving air mass going a
different direction.
CAT
really
worry
fly
I haven't read Machado's book, so I don't know what he says and what he
doesn't. I would disagree that there's never any turbulence outside of a
thunderstorm that you need to worry about, or that there's never any
moderate turbulence in which newer planes might have a concern. Those kinds
of absolutes seem troublesome to me.
need
I would say that it's true that most of the time. Just make sure you are
paying attention to winds aloft forecasts, especially comparing wind speed
and direction changes over the various altitudes. Strong winds, or
significant shear, can result in significant turbulence.
I guess to me the thing to keep in mind is that continuous turbulence is
unlikely to be the real issue. If you can stand the turbulence, the
airplane can. Regardless of when it was built. The problem is that you
could be flying along, tolerating the turbulence, and then run into
something more significant.
As Mike says, slowing down to match your comfort level is always a good
thing. There's nothing worse than an anxious pilot. Even if you know the
airplane can handle the turbulence, you need to be at ease. Even an older
airplane is likely to be able to handle stronger turbulence than you feel
comfortable with.
The real question is whether you are potentially going to hit some strong
turbulence without any warning. For this, the turbulence you're feeling now
is less important than things like current and forecast weather and pilot
reports.
Bottom line: it's true that most pilots rarely, if ever, experience
turbulence strong enough for Va to be a real issue. But it can happen, and
usually it happens without warning. Furthermore, for both pilot and
passenger comfort, it's helpful to slow down in turbulence, even if the
airplane is in no danger of being hurt. As with all aviation decision
making, being conservative is a fine thing with respect to flying at or
below Va.
For what it's worth, I think the chances of the wings falling off are the
least of one's worries. More of an issue are all the other parts in the
airplane that are important to a successful flight. It would still require
some heavy turbulence to cause a problem, and I don't think this difference
should mean that pilots should be braver in the face of turbulence. It's
just an interesting academic aspect to the issue, IMHO.
Pete
Peter Duniho
"Gary Drescher" wrote in message
news:T_z9d.436094$8_6.136539@attbi_s04...
Vne does not vary with weight; Va varies in proportion to the square root
of gross weight, becoming a stricter limit when weight is lower. That's
because the less mass you have, the more acceleration is produced by a
given force.
IMHO, you are making things more confusing, not less.
Yes, what will break the structure is force. But when we talk about "G's",
typically we are describing a *factor* multiplied with the weight of the
airplane, not "acceleration due to gravity". In that context, all "G's"
means is "a factor increasing the nominal 1G force experienced by the
airplane".
For example, in a bank, lift needs to be increased in order to maintain
vertical speed (i.e. prevent up or down acceleration), usually at zero. At
a high enough bank angle (much higher than any normal operation would
require), the "G's" exceed the certification limit. Those "G's" would be a
static state, not due to acceleration of the airplane (if allowed to turn,
the airplane would also be accelerating, but this acceleration isn't
directly related to the "G's" experienced...if you could somehow counteract
the lateral force caused by the increase in lift, the wings would still
experience increased "G's", but the airplane would track straight ahead).
Vne is not typically related to lifting force at all, but rather to other
things like flight control flutter and longitudinal strength of airframe
structures (e.g. drag pulling the wings backwards). In level flight, at any
airspeed, the wing is generating exactly as much lift as there is weight of
the airplane. The force (lift) is constant.
Va, on the other hand, is related to a variety of other things. In the
sense that those things have to do with rapid changes in airfoil loading,
they are related to acceleration. But ultimately, those limits still have
to do forces imposed on structure. The acceleration is relevant -- higher
acceleration results in higher G forces on structure -- but the reason that
Va changes due to weight has less to do with the distinction between
"force", "G's", and "acceleration" and more to do with the fact that there
are internal structures carrying loads that don't change with total gross
weight of the airplane.
It's true that "the less mass you have, the more acceleration is produced by
a given force", but the reason this is relevant here is not because
acceleration is the problem per se. Rather, it's because there are
components in the airplane with a fixed load that, with the increase in
total acceleration of the airplane, could experience loads higher than
designed for. Because of these, the acceleration limit of the entire
airframe needs to be held constant. If it weren't for that, increased
acceleration would not be a problem, because the total load (force) at lower
weights would be the same, and it's force that breaks things, not
acceleration.
As this relates to the original statement, Va is the only airspeed related
to "keeping the force from being excessive". You can fly above Va and below
Vne, and still create out-of-limit *force* on the airframe, enough to damage
or even break the structure, simply by exerting too rapid a control movement
(on the elevator, for example). Vne does nothing to prevent this; only Va
does (and it's not perfect either...there exist gusts in nature than can
still exceed the structural limits at or below Va).
IMHO, arguing that Vne is only about force and Va is only about acceleration
is misleading and only serves to confuse the issue. Ultimately, they are
*both* about force imposed on various parts of the airframe structure; they
just happen to be addressing different *force-related* issues.
Pete
Old October 8th 04, 08:22 PM
Gary Drescher
Oops, major slip: I meant to say Vno, not Vne.
--Gary
et...
Va
plane
given force.
--Gary
Old October 8th 04, 11:03 PM
Stefan
First, mountain waves cause up and downdrafts, but they are as smooth as
you can imagine. What you mean is rotor. Well, if you really want to
know how turbulence really feels, go to your friendly glider operator
somewhere in the mountains when there is wave and ask for a ride into a
rotor. As a side effect, you will also learn what a "steep turn" is.
Back to your question: There is no point in demonstrating how brave you
are. If you feel uncomfortable, slow down to Va. there is nothing wrong
in staying on the safe side.
Stefan
Turbulence Anxiety Doug Piloting 19 June 24th 04 12:51 AM
My First Time In Severe Turbulence (Long) David B. Cole Instrument Flight Rules 6 March 10th 04 10:21 PM
Thundersnow - Destructive turbulence? Peter R. Piloting 6 January 7th 04 04:30 PM
Wake turbulence avoidance and ATC Peter R. Piloting 24 December 20th 03 11:40 AM
How much turbulence is too much? Marty Ross Instrument Flight Rules 8 August 21st 03 05:30 PM
