Some more chow for thinkin'...
I've gotten plug fouling a couple of times on my C-172N, and cleared it with a runup to 2000 and 30-60 seconds of lean-off, with the point of leaning being "when the engine starts getting rough, and then a little more." We have a single-probe EGT and I watch it and it rises but rarely above what you'd see at cruise. Of course, a single-probe EGT doesn't tell you all that much, either. A few weeks ago, this procedure failed to clear a 200RPM dropoff, so I aborted and taxied back. The problem turned out to be a failed ignition lead. We've also got one cylinder with passable but low compression (63/80) which we suspect is a valve problem. If there's some blow-by going on here that could easily provoke the plug fouling which has been happening more regularly. We still get good static and cruise RPM and the engine seems smooth overall but we are keeping a closer eye on it. Also, as someone else here mentioned, prop dinging is an issue anytime you run things up. We normally runup to 1800 for the mag check. Best, -cwk. |
Clearing a fouled plug | Roger Long | Piloting | 3 | July 6th 04 05:53 AM |
