Paul,
Tapping the brakes prior to retraction is one of aviation's old wives tales that just hangs in there. The gear wells are large enough to hold the tires even if they have some bulge from spinning (which isn't much anyway on our slow little bugsmashers). There are some transports in which the manual calls for tapping the brakes and some in which it specifically says not to as the sudden stop on large tires and wheels can cause the tire to slide on the rim. Check the manual for your airplane for winter operations. Some suggest to delay gear retraction for a bit to help blow off snow/slush/water. The inertia from the spinning tire usually tosses off most of the contamination (allowing it to freeze to the underside of the wing g) and waiting a bit to suck the gear up allows the airflow to take it off the brake discs and other, stationary, portions of the gear. Having the gear freeze up is pretty rare. More common will be that you'll taxi through some snow that gets on the brakes, it melts on the discs and then freezes one or both of the brakes after takeoff. Just land on centerline to give yourself room for a swerve as it takes a moment or two of sliding tire(s) before the brake unfreezes and you have rolling control. Naturally, it occurs when you make one of those lucky, smooth touchdowns and you hear the squeal of a tire sliding, then the pop as the ice lets go and things go back to normal. Not usually a big deal, but folks have gone into the snowbanks adjacent to the runway due to not reacting quickly enough. All the best, Rick (Paul Tomblin) wrote in message ... This will be my first winter flying the club's Lance. One instructor told me that you want to tap the brakes before retracting the gear to dislodge any slush or snow so that it doesn't freeze in the wheel well, and I read somebody else saying that you should hold off retracting the gear after take-off for a little while to blow the slush and snow off. Should I do one or the other or both? |
Interesting. Life history of John Lear (Bill's son) | Big John | Piloting | 7 | September 20th 04 05:24 PM |
Interesting Resume (V Long) | Bob Chilcoat | Piloting | 24 | September 13th 04 06:44 AM |
Wife agrees to go flying | Corky Scott | Piloting | 29 | October 2nd 03 06:55 PM |
Ellery Queen and the Case of the Missing Magneto Gear Teeth | MikeremlaP | Owning | 3 | July 26th 03 03:01 AM |
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 12:35 AM |
