The only thing that I see wrong with this is that the cell "tower" needs
to connect to the wired phone system. We know that it can't be hardwired, that would be one hell of a long cable! So, as the "tower" needs to transmit and receive (transceiver) from other transceivers on the ground that are hardwired to the phone system. You can put the ground transceivers on a different frequency pairs, but that's a whole new world wide system! Brian Case wrote: Actually it could work very well, and I have seen this proposal from several different sources. The Idea is to install a low power cell phone tower into the airliner. As I understand it that signal bar you see on you Cell phone is dictates how much power the cell phone uses to transmit. So the closer you are to the tower the less power it uses to transmit. This is why you phone batteries probably last longer in town than the do out in the boondocks. By installing the tower in the aircraft you are only a few hundred feet from the tower (at the most). The Cell phones will get an excellent signal from it and will drop to the lowest transmit power setting, Thus the interference with towers on the ground should be minimal. I am not an expert on these, I am just repeating how it was explained to me. Brian "Morgans" wrote in message ... "Bob Chilcoat" wrote in message ... I noticed on the evening news the other night that someone is trying to get a modular mobile "cell tower" approved that would be installed in commercial aircraft so that passengers can use their own mobile phones. It will be interesting to see how the FCC and FAA handle this one. -- Bob (Chief Pilot, White Knuckle Airways) Still won't work. The frequency the cell in the air is on, will be hitting dozens of towers on the ground, making them unable to use that frequency for other users on the land. |
Watch them 12V Cell Phone Adapters TSA Panics Again | NW_PILOT | Piloting | 7 | October 13th 04 04:33 AM |
Cell Phone in small plane | Ron | Home Built | 1 | August 6th 04 02:10 PM |
Flying weather on your cell phone | Jay Honeck | Piloting | 6 | April 24th 04 01:59 AM |
Interesting use of cell phone to command a sharp roll to the right! | Peter Bondar | Instrument Flight Rules | 10 | December 19th 03 02:27 PM |
Palm cell phone and aviation | Maule Driver | Piloting | 3 | November 24th 03 11:52 PM |
