Winter flying with retractable gear?
Old October 13th 04, 08:06 PM
Rick Durden
Robert,
Don't know where you got the idea a B-17 would "tip over" should the
gear be retracted with the tires rotating. The gear retracts in its
plane of rotation. As a result of your post, I got in touch with one
of the folks who gives checkrides in B-17s (and all other WWII
multi-engine aircraft) and was advised that the subject is discussed
from time to time, but is an old wives tale. Boeing does not call for
the brakes to be used after takeoff on their WWII bombers. I was told
that the CAF procedure is not to touch the brakes on the B-17 to stop
the wheels from rotating. The matter tends to be airplane specific,
on the B-29 they recently started using the brakes because they are
concerned about clearances with the gear doors/wells, but he said that
was the only one. If you look at the gear for many of the WWII and
later large aircraft, there are red marks on the tires that line up
with red marks on the wheels so the crew can see if the tire has slide
on the wheel.
All the best,
Rick
(Robert M. Gary) wrote in message . com...
(Paul Tomblin) wrote in message ...
This will be my first winter flying the club's Lance. One instructor told
me that you want to tap the brakes before retracting the gear to dislodge
any slush or snow so that it doesn't freeze in the wheel well, and I read
somebody else saying that you should hold off retracting the gear after
take-off for a little while to blow the slush and snow off. Should I do
one or the other or both?
There are two things here. Tapping the brakes is something started in
WWII because a B-17 would tip over when the gear come up if the wheels
were spinning (imagine the gyro action happening on those big wheels).
I believe most large aircraft today automatically apply brake pressure
when the hydro lifts the gear.
In the Mooney world we always read about Mooney pilots taking off,
getting slush in the gear and then freezing at altitude. I don't know
how tapping the brakes would change that though.
-Robert, CFI and Mooney owner
Old October 17th 04, 01:21 AM
Paul Sengupta
"Rick Durden" wrote in message
on the wheel.
We have that on all our planes here in the UK.
It's one of the things to check on the pre-flight, that the tyre hasn't
rotated on the rim, possibly damaging the valve.
Paul
Interesting. Life history of John Lear (Bill's son) Big John Piloting 7 September 20th 04 05:24 PM
Interesting Resume (V Long) Bob Chilcoat Piloting 24 September 13th 04 06:44 AM
Wife agrees to go flying Corky Scott Piloting 29 October 2nd 03 06:55 PM
Ellery Queen and the Case of the Missing Magneto Gear Teeth MikeremlaP Owning 3 July 26th 03 03:01 AM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
