"Peter" wrote in message
... You meet the night cross country requirement with either flight listed above. There's no requirement for a solo night cross country of any distance in the regs. If you've done 10 night takeoffs and landings you meet the requirements for that part of the reg. My reading of the first paragraph above is that *both* (i) and (ii) are required, and the word "night" does apply to both (i) and (ii). Yes, it does. I assume that Peter Clark was not implying that the XC flight required by 61.109(2)(i) is not required to be done at night; rather, I read his statement to (correctly) mean that there's no *SOLO* night XC requirement. The only night XC requirement specifically requires an instructor to be on board. I have 11 takeoffs after Civil Twilight, and 21 landings after Civil Twilight, so (ii) should be satisfied. Yup. I now have (i) also but after advice from some people who should know I did it solo. There was no requirement to do so. The flight you did solo doesn't do anything to help you meet any of 61.109. However, from your original post, it appears that you already had the necessary dual flight required by 61.109(2)(i), so you're fine in that respect. It is possible that the words "night flight TRAINING" (my emphasis) refer to dual flying because in practice that is what the student will have to do; at that stage he won't be legal to do it solo. The student is legal to do it solo if his instructor signs him off to do so. I hope that you had the necessary instructor endorsement before you made your 119NM (239NM? you never said whether it was one-way or round-trip) flight. As far as what "night flight training" means, it means exactly what it would seem to mean to someone NOT trying to read between the lines. It's a night flight during which training is taking place; that is, an instructor is on board and giving training. It means that because the FAA wants an instructor on board, not because the pilot would not otherwise be qualified to make the flight (since, after all, it's possible the student pilot would be qualified to make the flight without the instructor). In my case, I have some 400 hours, lots of IFR/IMC time (on a UK license), and the UK night rating, so can fly at night solo or even IFR in IMC. In a UK-registered aircraft and/or in the UK, of course. AFAIK, the UK license doesn't make you legal in the US, flying a US-registered aircraft. It's not clear from any of your posts which certificate (the UK license or the US student pilot certificate) you're using as the basis for legality for the various flights you're making, or where those flights were made. I have heard of people who did their 100nm night flight solo. There are no such people. The regulation clearly requires an instructor to be on board in order to meet the requirements given. Perhaps you have, instead, heard of people who did *A* 100NM night flight solo? With the appropriate instructor endorsement (or other qualifying circumstances), that would be permissible, though would not help the pilot achieve the requirements given in 61.109(2). Are you saying that Americans are able to get an FAA PPL without doing 10 *night* takeoffs and landings and without flying 100nm fully at night? Anyone, American or not, can get an FAA Private Pilot Certificate without doing those. However, they will have a "no night flying" restriction on their certificate. The rest of us had to do the required night training, as clearly described in the regulations. Pete |
On Wed, 13 Oct 2004 13:58:27 -0700, "Peter Duniho"
wrote: "Peter" wrote in message .. . You meet the night cross country requirement with either flight listed above. There's no requirement for a solo night cross country of any distance in the regs. If you've done 10 night takeoffs and landings you meet the requirements for that part of the reg. My reading of the first paragraph above is that *both* (i) and (ii) are required, and the word "night" does apply to both (i) and (ii). Yes, it does. I assume that Peter Clark was not implying that the XC flight required by 61.109(2)(i) is not required to be done at night; rather, I read his statement to (correctly) mean that there's no *SOLO* night XC requirement. The only night XC requirement specifically requires an instructor to be on board. Yep, I stand corrected in that the 3 hours night training "that includes" would mandate the cross country be part of that 3 hours and thus logged as dual received wouldn't it. So the extra solo night cross country wouldn't be useful for anything under this part. In a UK-registered aircraft and/or in the UK, of course. AFAIK, the UK license doesn't make you legal in the US, flying a US-registered aircraft. It's not clear from any of your posts which certificate (the UK license or the US student pilot certificate) you're using as the basis for legality for the various flights you're making, or where those flights were made. If it is a standard UK certificate, wouldn't his easier path be getting a US PPL based on foreign cert, a-la 61.75? Anyone, American or not, can get an FAA Private Pilot Certificate without doing those. However, they will have a "no night flying" restriction on their certificate. Actually, I believe you might be mistaken on this one - the only night exemption is I can see is 61.110 which appears to apply to Alaska only. |
"Peter Clark" wrote in message
... [...] If it is a standard UK certificate, wouldn't his easier path be getting a US PPL based on foreign cert, a-la 61.75? You'd think. But each pilot has their own circumstance. I'll take it as granted that if a pilot feels it's easier to go through the "long form" certification process than to convert a UK certificate, then it is. ![]() Or perhaps in spite of all that aeronautical experience, he doesn't actually hold a convertable certificate. I don't know. Actually, I believe you might be mistaken on this one - the only night exemption is I can see is 61.110 which appears to apply to Alaska only. Hmmm...interesting. Either my memory is too fuzzy, or this is yet another example of a subtle change that occurred in 1997 (if I even have the year correct), and which I've failed to note. They appear to have kept in the general (non-Alaska) exception for gyroplanes, powered parachutes, and weight-shift-control aircraft. I could swear that, at least at some point in my past, they permitted general "no night flying" certificates, even for pilots outside of Alaska. Of course, the main point is that to be allowed to fly at night, all holders of an FAA certificate obtained through the usual process must meet the night training requirements. Pete |
another example of a subtle change that occurred in 1997 (if I even have the year correct), and which I've failed to note. They appear to have kept in the general (non-Alaska) exception for gyroplanes, powered parachutes, and weight-shift-control aircraft. I could swear that, at least at some point in my past, they permitted general "no night flying" certificates, even for pilots outside of Alaska. You're correct... but they closed that. Now, you can only get the exception living in Alaska, but I _think_ you have to go back and do the night stuff within six months or something like that. I had to do the night training (which led to a last-minute hop the night before my checkride to get the rest of the landings in) but it was all done with an instructor (the XC is a story for a different time...). I think they closed the exemption because too many people were trying to cheat the restriction and were having accidents (read: got themselves killed) so they figured it was better to make everyone do it even if they aren't going to use it again. Now, we can debate the intelligence of VFR XC's at night in single-engined airplanes for a long time to come... personally, I don't fly more than a few miles from my home area (where I can reconginze the landscape and airports, and can orient just by seeing Atlanta on the horizon) at night, and even then I won't go without a working, lighted GPS. |
ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 27th 04 11:49 PM |
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Piloting | 0 | September 22nd 04 07:13 PM |
Canadian IFR/VFR Flight Plan | gwengler | Instrument Flight Rules | 4 | August 11th 04 03:55 AM |
Canadian IFR/VFR Flight Plan | gwengler | Piloting | 3 | August 9th 04 08:39 PM |
