On Mon, 12 Jul 2004 01:15:57 -0700, jerry Wass wrote:
Ron Wanttaja wrote: I've been told I have the "last model" type of Goodyears...only three clips, and they aren't the little metal nubs most people seem to have. Mine are spring steel, about 2-3" long, rivet to the outside of the drum, and have an angle at the end to fit into the brake disk and lock it in place. OH! for a shop dwg. of one of those new clips!!! or mebby a couple of pics?? Certainly: http://www.wanttaja.com/goody1.JPG http://www.wanttaja.com/goody2.JPG The first picture is taken from the side, the second one is taken from above. The spring is bent in a sort of "J" at the end, and the short leg goes into a square slot in the brake disk that is very similar in appearance to the normal gear slots. Note that I've got a screwdriver blade slipped under the spring to flex it slightly. The springs are pretty stiff. There are three of them on each wheel, and all three must be held open to get the wheel on or off. I've a set of tiny oak wedges to do the honors. I've got ~250 hours on the airplane, and no problems with the springs. Ron Wanttaja |
Ron...
I thought I could help you but when I read that hangar tale about "being told I have the last issue by....nonsense, I gave up. But the pictures, the pictures make all the difference. You have what are known as gear tooth drive discs and matching wheels. "Gear tooth drive discs are retained by cantilever clips which are a part of the wheel. While I take a look at more data, Goodyear wheel and brake became part of Loral, and then Loral sold it to a company who intended to stay in the business making the stuff. I have their name, too. But they could care less about you. They decided on the big wheels are for making money and so stopped anything to do with the little ones. I met the lady sales manager several years at the mandated for mechs FAA meeting where the vendors would put on slide shows and pay for the displays. She said she would sell all the remaining pucks for our brakes (Cessna 140) at a cut rate cost. The next meeting....I said what? No, and later the cost was outrageous. She did impart some useful info. When forced to change from asbestos based pucks, the next model pucks were terrible. The third generation were good. Sigh. I have an old Spruce catalog page which notes the Gear Tooth Drive Disc for the Bellanca 260, Cessna 172, 175, 180, 182, 210 and Skylane. The image is 1/6th of a page but all the part numbers are readable and the parts are listed for the brakes. The wheels, of course, are not brakes, and I have no info on them. What, specifically, did you need? Any further answers will necessitate you telling me how to upload pix as you did. You have my email address if that is easier. Has this helped? Neal |
Ron...
Not knowing you had enough data, I kept looking for the wheel to match and did tonight in an old catalog. I found the three clip arrangement more promising than the smaller clips. None of us have ever seen your model or the model they made for the 150s, also "geared" type. Neal |
Building the Po' Boy Bending Brake | Veeduber | Home Built | 14 | March 1st 04 06:15 PM |
Sheet metal shear/press brake | VideoFlyer | Home Built | 7 | October 7th 03 07:08 PM |
Brake caliper flange | Stealth Pilot | Home Built | 5 | July 7th 03 04:19 PM |
Brake line design question | Charlie Smith | Home Built | 0 | July 2nd 03 12:31 PM |
