![]() "H.P." wrote in message om... He was returning the plane to the Danbury Flight School at DXR from Nantucket (ACK). Drawing a straight line on a map from Nantucket to Danbury, Madison and Killingworth are on the same line and Killingworth is 2-3 miles closer to Danbury. Griswold Airport (MPE) is in the same town where he went down (Madison).Wonder how (specifically) the dislodged prop affected the aerodynamics of the Warrior and his chances for a controllable glide. (Student here, please be be kind!) " An account of an aerobatic Pitts losing a prop said that the pilot used full forward stick and the aircraft still flared with nose up just before the pilot got it on terra firma. If he hadn't gotten it down it would have gone into a flat spin. I remember reading about it in the nineties. Of course, a part of the crankshaft departed with the propeller. To me, losing a prop on a single-engine tractor aircraft means instant loss of power, an aft CG outside of the envelope, and a life-threatening encounter with the earth's gravitational pull. |
" jls" wrote: To me, losing a prop on a single-engine tractor aircraft means instant loss of power, an aft CG outside of the envelope, and a life-threatening encounter with the earth's gravitational pull. A prop for most light aircraft weights about 80 pounds for a constant speed unit, much less for a fixed pitch prop. I don't anticipate that on most GA aircraft the CG will go so far aft that you'll have control problems,unless already loaded with the CG well aft. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
On Fri, 15 Oct 2004 06:13:05 -0800, Dale wrote:
In article , " jls" wrote: To me, losing a prop on a single-engine tractor aircraft means instant loss of power, an aft CG outside of the envelope, and a life-threatening encounter with the earth's gravitational pull. A prop for most light aircraft weights about 80 pounds for a constant speed unit, much less for a fixed pitch prop. I don't anticipate that I have the big 3-blade Hartzel on the Deb. It weighs 83#. The 2-blade it replaced weighed 57# Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com on most GA aircraft the CG will go so far aft that you'll have control problems,unless already loaded with the CG well aft. |
![]() To me, losing a prop on a single-engine tractor aircraft means instant loss of power, an aft CG outside of the envelope, and a life-threatening encounter with the earth's gravitational pull. Can't speak for all planes but single engine Cessna's can lose the prop and not get anywhere near the aft CG. I have already done that calculation for my 182. Lose the prop and I don't even get to the back half of the CG envelope. |
A quick back-of-the-envelope (unintentional pun) calculation, assuming a
Cherokee/Warrior prop weighs around 25 lb and is 6" back from the datum shows a shift in CG of about 1.5" aft. Hardly life threatening. OTOH, without a prop, the glide ability would really be improved, and it might be very difficult to judge an approach under those circumstances. He might have just landed really long compared with where he was hoping to set it down. My dad used to tell the story of a Corsair prop that departed the a/c during a runup somewhere in the Pacific. It flew all the way across the airfield at low level and was found several hundred feet into the jungle at the end of an impressive swath cut through the bougainvillea. Depending on the altitude and RPM at the time of loss, I can easily imagine a lost prop traveling a mile or two before it hit the ground. -- Bob (Chief Pilot, White Knuckle Airways) I don't have to like Bush and Cheney (Or Kerry, for that matter) to love America " jls" wrote in message ... To me, losing a prop on a single-engine tractor aircraft means instant loss of power, an aft CG outside of the envelope, and a life-threatening encounter with the earth's gravitational pull. |
("Bob Chilcoat" wrote)
My dad used to tell the story of a Corsair prop that departed the a/c during a runup somewhere in the Pacific. It flew all the way across the airfield at low level and was found several hundred feet into the jungle at the end of an impressive swath cut through the bougainvillea. Depending on the altitude and RPM at the time of loss, I can easily imagine a lost prop traveling a mile or two before it hit the ground. Prop thought fully feathered meant something else. Montblack |
"Montblack" wrote in message
... Prop thought fully feathered meant something else. Do you leave the prop feathered while doing a runup on a Corsair (or any other airplane with a feathering prop)? I wouldn't have thought so. |
On Fri, 15 Oct 2004 09:37:17 -0700, "Peter Duniho"
wrote: Do you leave the prop feathered while doing a runup on a Corsair (or any other airplane with a feathering prop)? I wouldn't have thought so. I don't think the Corsair had a full feathering prop. Wouldn't be any point and would just add more complexity to an already complex airplane. Never heard any mention of any WWII pilot feathering the prop on a Corsair, but I don't know everything. Corky Scott |
On Fri, 15 Oct 2004 13:23:11 -0400, Corky Scott
wrote: On Fri, 15 Oct 2004 09:37:17 -0700, "Peter Duniho" wrote: Do you leave the prop feathered while doing a runup on a Corsair (or any other airplane with a feathering prop)? I wouldn't have thought so. I don't think the Corsair had a full feathering prop. Wouldn't be any point and would just add more complexity to an already complex airplane. Never heard any mention of any WWII pilot feathering the prop on a Corsair, but I don't know everything. Corky Scott I don't know everything either (shhh....!!!) but you can't feather the prop on a Corsair. Bela P. Havasreti) |
![]() Bella Or any other single engien WWII Fighter. The P-38 had Curtis Electric Propellers that could be feathered. Big John `````````````````````````````````````````````````` `````````````````````````````` On Fri, 15 Oct 2004 19:10:13 GMT, Bela P. Havasreti wrote: |
George W. Bush Abortion Scandal that should have been | Psalm 110 | Military Aviation | 0 | August 12th 04 09:40 AM |
F4U inverted gull wings | Bob M. | Military Aviation | 52 | July 16th 04 02:11 PM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
PFC Lynch gets a Bronze Star? | Brian | Military Aviation | 77 | August 2nd 03 11:15 AM |
