Question from a new flight student (whopping 7 hours!)
Old October 17th 04, 03:45 PM
C J Campbell
"Cub Driver" wrote in message
On Fri, 15 Oct 2004 14:22:12 -0600, Newps wrote:
This would put you at the wrong altitude at a great deal of airports.
Doesn't causing a safety hazard bother you?
Nope.
Please don't fly in southeastern New Hampshire. Promise?
Something you may not know: many airports have more than one published
traffic pattern altitude. If you are depending on all the other airplanes
flying the same pattern and same altitude as you are, you are the one
creating a safety hazard.
Old October 15th 04, 08:59 PM
Corky Scott
On Fri, 15 Oct 2004 19:52:08 GMT, zatatime
On Fri, 15 Oct 2004 12:38:52 -0600, Newps
I'm going to 1000 feet.
z
How's that? If you look at the field elevation on the sectional, and
add 1000 feet, that's the pattern altitude isn't it? Are there lots
of airports that specify a non standard pattern altitude?
Corky Scott
Old October 15th 04, 10:18 PM
Newps
z
Some airports have a published pattern altitude of 800 feet.
Old October 15th 04, 10:33 PM
zatatime
On Fri, 15 Oct 2004 15:59:38 -0400, Corky Scott
z
Nope. Many airports (and most I fly in and out of) use an 800 foot
TPA, which is the original "standard TPA."
Are there lots
As I see it, yes there are. All the airports that have a 1000' TPA
are "non-standard," although the rule of thumb you have written has
become it's own standard of sorts. This is why I brought it up. If
you're flying in a Piper at 1000' thinking it is correct, and I'm
flying a Cessna at 800' which is what was published, we're going to
have a problem because we won't be able to see each other if we're in
close proximity. Also when looking for traffic, if the traffic is at
different altitudes it makes it harder to spot them. I could cite
other examples, but I think you'll get the point. There are also
airports with different altitudes for large aircraft, or opposite
traffic rules for rotorcraft, etc...
I feel fairly strongly that operations around an airport should be as
predictable as possible since this is where you will most likely find
numerous aircraft sharing close quarters. Flying a proper altitude is
one of the things that should be consistent for all traffic, and it
isn't like it's really hard to find the answer, or ask Unicom if
you're unsure.
(This may be wrong but,)I believe when a TPA is not explicitly stated
in the AF/D the expected TPA is 800' AGL.
HTH.
z
Old October 15th 04, 11:18 PM
Newps
TPA is always a suggestion. Never a reg.
Old October 15th 04, 11:23 PM
Newps
At all airports that can expect some higher performance aircraft like
King Airs and biz jets they will have a second published pattern
altitude, almost always 1500' AGL. 99%+ of these aircraft are low wing.
So how are they supposed to see anybody?
Old October 16th 04, 02:29 AM
zatatime
On Fri, 15 Oct 2004 16:23:58 -0600, Newps
99% of them are also alot faster than a typical single so the
opportunity to remain over a lower aircraft is significantly reduced,
and still allows for picking up traffic ahead of the larger aircraft.
They also fly a larger pattern, and where this condition exists
(generally speaking) have control towers on the field to aid in
separation. The 500' vertical separation also helps reduce the risk of
a mid-air.
z
Old October 15th 04, 11:59 PM
Teacherjh
close proximity.
The hazard indicated is real, but the altitudes are no longer correct.
According to my AIM (2000, 4-3-3) a pattern of 1000 feet is reccomended unless
established otherwise. However it seems that some airports have retained the
historical 800 foot altitude you indicate was once standard, but have not
ensured that the AF/D is apprised of this. Thus, us newfangled pilots (the
ones minted after VORs g,d) will enter at 1000 feet, only to be surprised by
folks 200 feet below us. (this was exactly what I found at GBR not too long
ago).
Jose
Old October 16th 04, 02:20 AM
zatatime
On 15 Oct 2004 22:59:15 GMT, (Teacherjh)
close proximity.
ago).
Jose
I guess there's a reason my muscles ache more than they used too. g
So, if an altitude isn't listed in the AF/D should we now assume its
1000'? And when it turns out to be 800, who is allowed to call the
FAA to have the entry modified? I've always assumed an 800' pattern
if I didn't see an entry (and have never had a problem), but what you
wrote seems to show a different standard than I was taught.
Thanks for the info.
z
(I guess the bottom line is to know the specifics of the airports you
operate at, and maintain consistency with the other pilots.)
Old October 16th 04, 02:47 AM
Teacherjh
1000'?
Yes. But be careful about assUme.
Anybody. Tell them what you've observed, and have them contact the airport for
verification. It's even better if you talk to the airport head first and get
appropriate contact info for the FAA. It's just a "correction" to the AF/D,
like any other correction (lake in the wrong place on the sectional, tower
mismarked, stuff like that)
Jose
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 02:54 AM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
question charity flight Dave Jacobowitz Piloting 1 November 14th 03 12:51 AM
