On Fri, 15 Oct 2004 15:16:20 -0600, Newps
wrote: Yeah right. I'm at 1000 AGL, meanwhile there's idiots flying over the airport at pattern altitude then leaving so they can get on their precious 45 degree entry. Sorry your argumaent doesn't hold water. Why would you leave the pattern to perform a 45 entry? At least my argument makes sense. z |
![]() zatatime wrote: On Fri, 15 Oct 2004 15:16:20 -0600, Newps wrote: Yeah right. I'm at 1000 AGL, meanwhile there's idiots flying over the airport at pattern altitude then leaving so they can get on their precious 45 degree entry. Sorry your argumaent doesn't hold water. Why would you leave the pattern to perform a 45 entry? You're kidding right? You would not believe what some people go thru to go out and get back on that 45. |
go out and get back on that 45. I've got to say that I've honestly never seen anyone leave the pattern just to re-enter on a 45. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() I've got to say that I've honestly never seen anyone leave the pattern just to re-enter on a 45. I do sometimes, though I come over the airport 1000 feet above pattern altitude. It's the standard "strange field approach", and it's also how you see the wind sock or segmented circle. Granted AWOS and GPS makes a lot of this obsolete, but radios don't make the plane fly. Jose -- (for Email, make the obvious changes in my address) |
"Teacherjh" wrote in message
... I've got to say that I've honestly never seen anyone leave the pattern just to re-enter on a 45. I do sometimes, though I come over the airport 1000 feet above pattern altitude. Maybe I misunderstand the original statement, but the procedure you describe doesn't have you leaving the pattern in order to re-enter on the 45. You weren't in the pattern in the first place, since (by your own statement) you were ABOVE the pattern. I often overfly the airport, head out and come back on the 45. But I can't recall a single instance when I was actually already on a legitimate leg in the traffic pattern, made a turn away from the pattern for the purpose of positioning myself on the 45, for the further purpose of re-entering the pattern. That just sounds silly to me. Pete |
![]() .... but the procedure you describe doesn't have you leaving the pattern in order to re-enter on the 45. [...] you were ABOVE the pattern. Correct. I was expanding a bit. Jose -- (for Email, make the obvious changes in my address) |
... ... but the procedure you describe doesn't have you leaving the pattern in order to re-enter on the 45. [...] you were ABOVE the pattern. Correct. I was expanding a bit. Maybe you can expand just a little more? ![]() statement "I've honestly never seen anyone leave the pattern just to re-enter on a 45", the words "I do sometimes". Do you, or do you not, ever leave the pattern just to re-enter on a 45? You seem to have said that you do, but the example you gave was not an example of you doing so. Honestly, I can't say it matters one way or the other...but I'd at least like to get straight what it is you said you do. ![]() Pete |
![]() Jay Honeck wrote: You're kidding right? You would not believe what some people go thru to go out and get back on that 45. I've got to say that I've honestly never seen anyone leave the pattern just to re-enter on a 45. Let me be more clear. Rwy 9/27 is in use. You are approaching from the NE, the dead side of the pattern if you will. In this situation I will always enter at midfield, on the crosswind, unless traffic does not permit. I can usually always get in on the midfield crosswind, worst case I turn upwind and fall in behind someone else. This is very rare. It is not uncommon for others to enter just like me except they will then make a right turn(approax 45 degrees) and fly away from the pattern on a southwesterly heading, into the face of other traffic entering on the 45, fly out a couple miles and then do a 180 for the sole purpose of entering the pattern on the 45. These people are nuts |
On Fri, 15 Oct 2004 20:42:49 -0600, Newps wrote:
It is not uncommon for others to enter just like me except they will then make a right turn(approax 45 degrees) and fly away from the pattern on a southwesterly heading, into the face of other traffic entering on the 45, fly out a couple miles and then do a 180 for the sole purpose of entering the pattern on the 45. These people are nuts Yes, they are. But so are you, declaring that "nope" it doesn't bother you that you may create a hazard by flyiing at a non-standard altitude in the pattern. The existence of stupid pilots is not a reason for you to behave stupidly, but a reason for you to be even more punctilious in doing the expected thing. In the case you describe, there is one hazard at the airport. But you are declaring your right to add a second one! all the best -- Dan Ford email: (put Cubdriver in subject line) Warbird's Forum www.warbirdforum.com Piper Cub Forum www.pipercubforum.com Viva Bush! www.vivabush.org |
On Sat, 16 Oct 2004 06:08:22 -0400, Cub Driver
wrote: The existence of stupid pilots is not a reason for you to behave stupidly, but a reason for you to be even more punctilious in doing the expected thing. In the case you describe, there is one hazard at the airport. But you are declaring your right to add a second one! Thank you. Stated better than I could have, but my sentiments exactly. z |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
question charity flight | Dave Jacobowitz | Piloting | 1 | November 14th 03 12:51 AM |
