Newps wrote:
Don't make this more difficult than it has to be. It doesn't matter where you live, where the plane is kept, where you get gas. If you take off and then at some point during the flight land at a point that is more than 50 miles away that is a cross country. You're trying to make it simple, but then you say "if you take off" and then say "at some point during the flight" but you don't tell me what you think a "flight" is or a "take off." Land every 5 miles if you wish but once you land more than 50 miles from the original point it becomes a cross country. And here you refer to the "original point." A "take off" can't reset the "original point of departure" Staying overnight can't reset the OPOD. So what does? Let me rephrase the first question again. I consider my hangar airport to be my original point of departure for a multi-day (1 week) XC "flight" in which I just happened to land and stay at an airport near my home. I flew some time in that local area more than 50 nm from the hangar airport, but less than 50 nm from the airport where I tied down for the week. I considered all that time to be one long flight more than 50 nm from home, requiring the same skills for flying there that it took to navigate there from my OPOD at the hangar airport. Question 1 was: can I log it all as XC time? If not, why not? Quite honestly, the flying I did there required far more XC skill than flying 51 nm from my hangar airport. I'll rephrase question 2, also. I'm flying from my home to Oshkosh and fly 300 miles, then land. The next day I want to fly another 300 miles towards my goal, but weather forces me to land 25 farther along. I consider the second day to be part of a single long XC flight to Oshkosh. Should I (can I) log the 25 mile stretch as XC time? If on day 3 I have to turn back to the day 2 airport because a front prevents my continued progess towards Oshkosh, can I (should I) log that as XC time? The answer depends on my OPOD, and my question is basically what is it legal to call an OPOD and what is it not. In case 1 I had reached a destination (near my home) but hadn't fulfilled the purpose of the flight or reached my "true destination" (visiting other airports near my home. In case 2 I was still trying to reach my destination (Oshkosh). What factors can I use to decide if I should "reset" my OPOD. We all agree just landing doesn't reset it, and the FAA says a new day doesn't reset it. Does anything reset it, or is it entirely up to me? Where do those here think the reset should occur? I personally keep different days flights as seperate but you could count a 10 day trip, flying each day, as one long cross country trip for logging purposes. So you'd see it as accepatble to log all the time in both cases as XC? |
On Mon, 18 Oct 2004 15:48:59 -0400, Bob
wrote: I personally keep different days flights as seperate but you could count a 10 day trip, flying each day, as one long cross country trip for logging purposes. So you'd see it as accepatble to log all the time in both cases as XC? I don't think he's considering using the trip for a certificate or rating, so the 50nm rule doesn't apply to that situation. z |
![]() You're trying to make it simple, but then you say "if you take off" and then say "at some point during the flight" but you don't tell me what you think a "flight" is or a "take off." I'm not the OR but... "take off" means to leave the ground and begin flying. "Flight" is defined by you, but presumably begins at a takeoff and ends at a landing. The landing cannot occur before the takeoff. Other than that, what happens in between is irrelevant. You can even land, get out of the plane, let somebody else fly the plane for a while without you (logging that as a separate flight) and then continue your original flight, without resetting your OPD. It's like Michigan or Pakistan - not contiguous but one entity. Q1 I consider my hangar airport to be my original point of departure for a multi-day (1 week) XC "flight" in which I just happened to land and stay at an airport near my home. I flew some time in that local area more than 50 nm from the hangar airport, but less than 50 nm from the airport where I tied down for the week. I considered all that time to be one long flight In that case it =is= one long flight. can I log it all as XC time? Yes. I probably wouldn't (in which case I'd split my "flight" into three parts for clarity to me), but under some cicrumstances I might log it all as XC. I'll rephrase question 2, also. I'm flying from my home to Oshkosh and fly 300 miles, then land. The next day I want to fly another 300 miles towards my goal, but weather forces me to land 25 farther along. I consider the second day to be part of a single long XC flight to Oshkosh. Should I (can I) log the 25 mile stretch as XC time? If on day 3 I have to turn back to the day 2 airport because a front prevents my continued progess towards Oshkosh, can I (should I) log that as XC time? The answer depends on my OPOD, and my question is basically what is it legal to call an OPOD and what is it not. Yes, and yes. The OPD is entirely up to you. What you call a "flight" is also entirely up to you. You can reset your OPD any time you like. Jose -- (for Email, make the obvious changes in my address) |
![]() Bob wrote: Newps wrote: Don't make this more difficult than it has to be. It doesn't matter where you live, where the plane is kept, where you get gas. If you take off and then at some point during the flight land at a point that is more than 50 miles away that is a cross country. You're trying to make it simple, but then you say "if you take off" and then say "at some point during the flight" but you don't tell me what you think a "flight" is or a "take off." You're kidding right? A flight is anything you want it to be. And you're not seriously asking what a takeoff might be are you Mr. Clinton? |
Newps wrote:
You're kidding right? A flight is anything you want it to be. And you're not seriously asking what a takeoff might be are you Mr. Clinton? I knew I'd get an answer like this when I wrote it. I was emphasizing how difficult it is to figure out what a regulation means and trying to pin you down. The point of my question was to ask what *you* (and others here) think it means and what you think the *FAA* thinks it means. Telling me "A flight is anything you want it to be" implies that I can log almost everything I've ever flown as XC time during one long "flight." I don't think the FAA would agree regardless of my personal opinion, and their opinion has more weight than mine does. Even if I think it was all one long flight, I don't think a DPE will. There must be some guidelines on this, and that's what I was trying to get to. |
Bob wrote in
: Newps wrote: You're kidding right? A flight is anything you want it to be. And you're not seriously asking what a takeoff might be are you Mr. Clinton? I knew I'd get an answer like this when I wrote it. I was emphasizing how difficult it is to figure out what a regulation means and trying to pin you down. The point of my question was to ask what *you* (and others here) think it means and what you think the *FAA* thinks it means. Telling me "A flight is anything you want it to be" implies that I can log almost everything I've ever flown as XC time during one long "flight." I don't think the FAA would agree regardless of my personal opinion, and their opinion has more weight than mine does. Even if I think it was all one long flight, I don't think a DPE will. There must be some guidelines on this, and that's what I was trying to get to. I personally would not log a flight, nor allow my student to log a flight as xc, if we did not land at an airport farther than 50NM from our home base without stopping at an intermediate point, ie., landing every 25 miles does not count as xc, and flying a 50NM leg within a 25NM radius of our home airport does not count as xc. I know this is not what the regs say, but I hold myself and my students to a higher standard. I also believe this was the intent of the regs, even though the exact wording leaves room for interpretation. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
When Rutan did the around the world with no refueling I wonder if he logged
it as XC? Makes you wonder.... |
Gig Giacona wrote:
When Rutan did the around the world with no refueling I wonder if he logged it as XC? Makes you wonder.... 216.1 hour local flight. 1 landing, full stop. :-) |
[Burt Rutan:] 216.1 hour local flight. 1 landing, full stop. :-)
Unless he's an ATP or military. Then it's XC. Jose |
"Gig Giacona" wrote in
: When Rutan did the around the world with no refueling I wonder if he logged it as XC? Makes you wonder.... Why would Rutan care about logging xc? Is he working towards a certificate or rating? Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Logging Time Consistently - Hobbs AND Tach | Carl Orton | Piloting | 11 | June 29th 04 09:52 PM |
FS: 1990 Cracker Jack "War Time Airplanes" Minis 6-Card (CJR-3) Set | J.R. Sinclair | Aviation Marketplace | 0 | April 12th 04 05:57 AM |
Time (years) SMOA | Paul Folbrecht | Owning | 15 | March 25th 04 03:30 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
